What engine do I have ?
Old Apr 20, 2005 | 08:25 AM
Jim W's Avatar
Jim W
Default What engine do I have ?
Just bought a 79 L82 Vette with very clouded history VIN # 1Z8749S442379. My biggest problem right now is trying to figure out what engine I have. The engine number from the driver side rear, by the bell housing is 140 0207 (there is a space between the 140 and the 0207). IF the number was 14010204 it would be a 80 to 85 4 bolt 350 out of a light truck, but there is NOT a 1 between the two numbers. I am even more confused by the heads, the only numbers I can find is upside down 413 which is under the rocked arm assemble between # 1 and 3 cylinder and 9 between 5 and 8 cylinders. The plugs are angled downwards and towards each other. I have looked on several web sites and ask the local gear heads and Chevy parts guys with out any answers. You guys are my last hope
Old Apr 20, 2005 | 08:29 AM
page62's Avatar
page62
Is there a number on the pad in front of the passenger-side head?
Old Apr 20, 2005 | 08:43 AM
Jim W's Avatar
Jim W
Default No
No there is not a number on the passenger side pad like most SBC
Old Apr 20, 2005 | 09:13 AM
kens 80's Avatar
kens 80
I don't know about the block, but if my memory serves me correct I think you have an early set of GM performance 2.02 slant plug heads. For the time they were the best GM had, but todays Vortecs are better.
Old Apr 20, 2005 | 10:43 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Almost all '79s used block #3970010; some very late production cars used #14016379; stock heads are #462624.
Old Apr 20, 2005 | 11:03 AM
gerry72's Avatar
gerry72
The only early angle plug 2.02 heads were the 292 turbo heads that were never used in production. Sounds like aftermarket to me.
Old Apr 9, 2018 | 06:16 PM
Stones8TC3's Avatar
Stones8TC3
I know this is an old post, but I just bought a 1980 with the exact same code (140 0207)...did you ever figure out what you had?
Old Apr 9, 2018 | 06:29 PM
Alan 71's Avatar
Alan 71
Hi S,
It appears that Jim W hasn't visited this site since August 8th, 2005.
So he may not see your post.
Maybe an e-mail?
Regards,
Alan
Old Apr 9, 2018 | 10:23 PM
Jebbysan's Avatar
Jebbysan
Dr. Detroit
I believe you have the 80-85 truck 350 and the "1" in the casting number is not visible due to casting anomaly......not uncommon on GM blocks to have missing or faint number on the pad as well as other places.
Jebby
Old Apr 10, 2018 | 06:10 AM
Stones8TC3's Avatar
Stones8TC3
Default Thanks
i found this from Wilcox, apparently the were truck/car and actually used in the 1980 Corvettes. I truly hope this is correct.
Old Apr 10, 2018 | 01:07 PM
NewbVetteGuy's Avatar
NewbVetteGuy
There's a few threads here on CF regarding this block.
-Dipstick on the passenger side, right?
CF Lore says that there was a 4 bolt version and a 2 bolt version of the 0207 block.
I found some more internet lore that says that the 0207 blocks are a bit lighter/ thinner and more crack-prone and mark the switch to the made in Mexico blocks.
https://www.corvetteforum.com/forums...4010207-a.html
Adam
Old Apr 17, 2018 | 12:07 AM
Bikespace's Avatar
Bikespace
My 1980 block (L48, numbers matching, factory manual) is block code 14010207. Passenger-side dipstick as Adam said (I thought it was a year thing, as my 79 has it on the drivers side). Now I'll have to stick my borescope in the oil pan and see if I have 2 bolts or 4.
To What engine do I have ?
