Door Panel update
Old Apr 30, 2005 | 11:14 PM
fjetb's Avatar
fjetb
please send me a copy, too! jetterb@rose.net
thanks !
Old Apr 30, 2005 | 11:30 PM
PizzenEwayMoney's Avatar
PizzenEwayMoney
can you email me the instructions. Thanks sean@cabinetshowcase.com
Old May 1, 2005 | 03:43 PM
JustinGJ's Avatar
JustinGJ
One trick I've found that works for me every time is to just grab a shop towel or other rag and slide it between the **** and panel. Then work the rag back and forth at different angles like you're drying your back off after a shower. The rag will grab one of the little ears on the clip and pop it right off. Absolutely no way to scratch anything this way either.
Old May 1, 2005 | 06:18 PM
71redskin's Avatar
71redskin
Default door panel
i just did mine today... the nut on the door handle is impossible to reattach...works fine with just the front nut. i used the flat tool for installation and removal of lock and crank... as far as reattaching actuator rod on the door handle i disconnected the rod from inside, put it in the handle and then put the handle in the door... witha pair of needle nose pliers and a lotta determination i got it back together and its workin fine
