Door Panel update
Old Apr 23, 2005 | 04:25 PM
foundvettelifeisgood's Avatar
Default Door Panel update
I bought a $5 tool at the parts store to remove the inside door lock **** clip. Using the tool, I ended up scratching the black paint off of that area of the door panel. With a closer look, all that is needed is a normal to small screw driver blade to push the clip off of the lock ****. For window cranks, the tool might be helpful and less destructive. I have power windows, so I don't know.
I got the exterior chrome door handle off the car and wrote up some instructions for anyone who is interested. I'll do the passenger side tomorrow.
Old Apr 23, 2005 | 06:18 PM
cbr900son's Avatar
cbr900son
I wouldnt mind a how to on the door handle thinking about doing this myself.
Old Apr 23, 2005 | 06:42 PM
It's an excel spreadsheet. Just let me know your email.
Old Apr 23, 2005 | 07:10 PM
ACECO's Avatar
ACECO
St. Jude Donor '04 & '05
Send me a copy if you would.
aceco@earthlink.net
TIA!
Old Apr 24, 2005 | 09:05 AM
cbr900son's Avatar
cbr900son
webishop78@hotmail.com thanks!
Old Apr 24, 2005 | 10:30 AM
Jughead's Avatar
Jughead
Senior Member since 1492
From: Just because I'm paranoid doesn't mean people aren't out to get me...
St. Jude Donor '09
Don't know how you'd manage to get the u-shaped clip off with just a screw driver Jay. I coulnd't even see the clip with my door panels. The lock **** was easier to remove for me than the window crank though.
I'll have to remove mine again soon and am no looking forward to that day.
Send me the sheet too
mozuch@aol.com
Old Apr 24, 2005 | 10:39 AM
kdf1986's Avatar
kdf1986
Hello I had the same problem putting new door panels on last night. I have the window clip remover tool, which is a long flat piece of metal with 2 sets of grooves cut in it, but I could not get it to work.
I studied the Chiltons manual and found one thing that helped me. The clip is referenced to the position of the window crank and door lock ****. I have manual windows, and that is what I was having trouble with. I noticed that in the drawing the clip is seated so that the opening faces the lenght of the handle. That meant the round part of the clip was opposite of the handle. I took a jewelers screwdriver, one of those real long skinny ones, and bent the tip at a 90 degree angle. only about 1/8 inch long. I then used it to hood the end of the round clip and managed to pull it out from the window crank.
Once I had the position relation between the window handle and the clip, I knew where to look for.
After the clip was off I checked the window handle against the tool. There is no way that it will fit and do what it is supposed to do.
kdf
Old Apr 24, 2005 | 03:46 PM
Email's sent...
I had no trouble seeing the clip on the lock ****, once I got down close to it and pulled outward on the **** and pushed inward on the panel.
I did the passenger door this morning in about 1/2 the time it took to do the driver's door. Hopefully the instructions will make it go faster for you guys too. The best tip on there is to loosen the latch mechanism at the right time to get the handle out of the door enough to separate the rod from the exterior handle.
I think reassembly will be difficult getting the rod on the new handle w/o scratching the new paint, getting the rear nut on the bottom of the new handle and getting the U clip back on the key cylinder.
BTW, my instructions include removing the key cylinder...you don't need to do this if you are just replacing the door handle. I was prepping for paint.
Old Apr 24, 2005 | 05:37 PM
vettelawyer's Avatar
vettelawyer
I would like a copy of your instructions. I've got brand new door panels sitting in my garage (I still need to order the outside door handles), and I plan on starting the job pretty soon. dfolkenf@tampabay.rr.com
Old Apr 24, 2005 | 10:26 PM
any4xx's Avatar
any4xx
I made a tool for this about 30 years ago and I still use it. I took a very small flat bladed screwdriver and bent the end of the blade into a hook. Instead of pushing the clip off, you stick the screwdriver in and grab the hook from the other side and pull it off.
Old Apr 24, 2005 | 10:36 PM
vetteboy1976kr's Avatar
vetteboy1976kr
Could you copy me on your instructions also?
vetteboy1976@hotmail.com
Thanks!
Old Apr 24, 2005 | 10:37 PM
kdf1986's Avatar
kdf1986
Hello tpiini
That is the same thing I do. If I can remember to bring my camera to work tomorrow I will download my photos. I used a very thin flat head screwdriver that I paid maybe 1.00 for. I put the flat head in a vise and bent it to a 90 angle with a 1/8 inch tip. Once I realized the relationship between the door handle and the clip it was easier to pull off the clip, rather than push it out from the front.
kdf
Old Apr 24, 2005 | 10:44 PM
ICEMAN59's Avatar
ICEMAN59
Please e-mail me a copy, it would be greatly appreciated, just to have it in my files. I'll need it one day, you know it.
Old Apr 25, 2005 | 11:44 AM
kdf1986's Avatar
kdf1986
Here is a comparison between the tool that I bought to remove the clips, and the screwdriver that I bent with a 1/8 inch 90 degree tip.
And the tool in action taking off the door lock ****.
kdf
Old Apr 30, 2005 | 12:53 PM
pra4sun's Avatar
pra4sun
kdf
The tool is a b***h to use. I got the clips off after about the 100th try. Definitely the hardest part of the job. I'm glad I caught this thread because I have to take my panels off again - to replace the lock sets.
Old Apr 30, 2005 | 01:11 PM
zwede's Avatar
zwede
Don't know about the door lock ****, but I've been using the tool for the window crank for years and it comes off fine every time??? For the door **** I use a small screwdriver.
Old Apr 30, 2005 | 02:34 PM
Carl Granquist's Avatar
Carl Granquist
I'd like to see a set of those instructions. My locks are fine but my windows rattle in both doors and I need to replace those bumpers someday soon. Thanks. <carlgranquist@comcast.net>
To Door Panel update
Old Apr 30, 2005 | 06:27 PM
carl a's Avatar
carl a
i never have a problem removing the clip with that flat tool,i have had one for 25yrs and the first thimg i do is make sure im pushing on the open side of the clip and push---it pops right off------------ to put it back you put the clip in the handle and push the handle on the shaft and push handle is back on
Old Apr 30, 2005 | 06:44 PM
Edzred72's Avatar
Edzred72
YEP...much easier
Eddie
Old Apr 30, 2005 | 07:17 PM
corpeventspecial's Avatar
corpeventspecial
please send me a copy, I to will be trying this shortly. corpeventspecial@aol.com
