72 POA Valve replacement
Old May 31, 2005 | 04:23 PM
jimcork1's Avatar
jimcork1
Default 72 POA Valve replacement
Has anyone replaced the POA valve & expansion valve with Eckler's parts on a 72 C3? If so how did it work out,, any difficulty or recommendations. Thanks 99 Nassau Blue
Old May 31, 2005 | 05:16 PM
Mr.Gearhead's Avatar
Mr.Gearhead
I replaced mine during the rebuild. Still at it...
Anyway, I found the stock unit has a different end on it than the new unit. The stock end lays flat against the upper hose tubing. The new piece has a few inches of coiled copper... I have not tested the system as of yet....
Old May 31, 2005 | 05:27 PM
shoptek's Avatar
shoptek
I think the NAPA poa valve is an identical replacement
Old May 31, 2005 | 05:37 PM
zwede's Avatar
zwede
Yes, it is. I got one several years ago and it is identical to the factory part except that it is adjustable (which comes in real handy when converting to R134a). However, I think NAPA has discontinued the POA valve. Atleast it doesn't show up on napas website.
Old Jun 1, 2005 | 08:20 PM
jimcork1's Avatar
jimcork1
Thanks for the info.. The POA we have is the Ecklers part. It hasn't been installed yet. We also have the new expansion valve. It would be nice to know how it worked when you get it operational. thanks 99 Nassau Blue..
To 72 POA Valve replacement
