Spark Plug Type
Old Jun 30, 2005 | 03:53 PM
Maymyvetteliveforevr's Avatar
Default Spark Plug Type
Can anyone help me with the correct plug I should be using to suit the changes made during the last engine rebuilt, since the standard R44TX just aren't working anymore. Stock engine is a 75, 350 L48 .060 gap 8.5 compression changed to 10 with a 350 horse cam. Stock was 165hp and the dyno states it's now 285. There were other changes but I don't think it's relevant to the plug change. Any advise would really be appreciated.
Thanks.
Old Jun 30, 2005 | 04:59 PM
zwede's Avatar
zwede
It would help if you told us what you mean by "not working anymore".
Generally when you increase compression you need a colder plug. For AC delco lower numbers are colder so maybe a R43TX.
But again, if you could detail what exacty isn't working you might get better advice.
You also want about a 0.045" or so gap.
Old Jun 30, 2005 | 05:03 PM
What I should have said was it's running too hot, the isolator is blistering and the electrode is wearing far to fast. Coolant temperature is running at around 190 deg. I also can't seem to get the engine to idle smooth, and I know that the word " smooth " can be left up to interpretation.
Thanks zwede
Old Jun 30, 2005 | 06:40 PM
When you have a plug that is let's say R43T or S or X. I believe "R" stands for resistor, is the 43 the heat range, and what does the T, S, & X stand for?
Old Jun 30, 2005 | 06:55 PM
BSeery's Avatar
BSeery
From: Exiled to Richmond, VA - Finally sold my house in Murfreesboro, TN ?? Corner of "Bumf*&k and 'You've got a purdy mouth'."
CI 6-7-8 Veteran
CI-VIII Burnout Champ
St. Jude Donor '06-'10, '13
Prefix -- R = Resistor
4 = 14 mm Thread
5 = Heat Range
T = Taper Seat
S = Extended Tip
Prefix --
B - Series Gap
C - Commercial
CS - Chain Saw
F - Fine Line 14 mm 5/8" Hex
M - Marine
LM - Lawn mower type
R - Resistor
S - Shielded (5/8-24 thread)
V - Surface Gap
Numbering
1st number denotes THREAD SIZE
2nd number denotes HEAT RANGE
Suffix
A - Clip Gap
C - Copper Core Center Electrode
C - Colder Version of M44 Plug
E - Special Design Electrode Extended Tip
F - 1/2" (12.7 mm) reach
FF - 1/2" (12.7 mm) reach, fully threaded
G - Pin Gap (cold -running)
I - Iridium Center Electrode
J - Boot Release Agent, Anti-Seize Compound
K - Special Design
L - Long Reach
--- 7/16" (11.1mm) reach, (14mm) thread
--- 3/4" (19mm) reach, (18mm) thread
--- 3/4" (19mm) reach, (14mm) thread (fineline)
LT - Long reach, .715" (18.16 mm), Tapered Seat
M - Special Design Electrode
N - 3/4" (19 mm) reach, 3/8" (9.5 mm) thread length
R - Resistor (Sport Vehicle Plugs)
S - Extended Tip
S - 7/8" (22.3mm) Moderate Long reach 23/32" (18.25mm)
T - Tapered Seat Shell Design
TS - Tapered seat with extended tip
X - Wide Gap (H.E.I.) (high energy ignition)
XL - Extra Long reach, 3/4" (19 mm) fully threaded
Y - 3 prong cloverleaf electrode
Z - Special gap (usually denotes wide gap)
5 - .050" (1.3 mm) gap
6 - .060" (1.5 mm) gap
8 - .080" (2 mm) gap
100 - Iridium
600 - Resistor Type
800 - Platinum Type
900 - Double Platinum Type
Old Jun 30, 2005 | 07:27 PM
Thanks alot BSeery, that's great, now I just need to find the right plug and so far it may be R43TX.
To Spark Plug Type
