What mods?
Old Aug 14, 2005 | 02:18 PM
GrandSportC3's Avatar
GrandSportC3
Cruise-In IV-V-VI-VII-VIII Veteran
St. Jude Donor '03, '06, '17
Originally Posted by MotorHead
I think your money would be best spent on dyno tuning, do you know what your A/F ratio is ? How do you know the motor is dialed in properly, you could be leaving 50HP on the table right now
Checked the plugs and they look perfect... They color is just right.. I think that my A/F is close to perfect...
Old Aug 14, 2005 | 02:19 PM
GrandSportC3
Originally Posted by lostpatrolman
For the uppers, I believe VBP makes soem tubular ones. Jim Meyer Racing also has uppers that they sell with their kit. They might sell them individually if you ask. I was able to get them to sell me just the lowers from their kit. Talk to them through email first though.
WOW - that's a nice setup!! Who sells that kit??
Old Aug 14, 2005 | 02:21 PM
GrandSportC3
Originally Posted by Twin_Turbo
I was going to suggest just that, those look to be extremely light, about as light as you can get. Would be nice to have the lower ones but then w/ a spring pocket added since O wants to keep the stock coil setup.
Well, for drag racing I'll have to stick with coil springs.. I hardly doubt that a composite front spring is going to give me enough weight transfer..
Old Aug 14, 2005 | 02:22 PM
GrandSportC3
What about the front spindles? That whole assembly is so heavy. Are there any aluminum units that would fit?
I believe that the aerospace front brake kit includes the spindles... That kit is about $500 and takes 50 lbs off the front of the car..
Old Aug 14, 2005 | 02:23 PM
GrandSportC3
Originally Posted by jcswm
I just did a google search on steel tube frames.... looks like you could drop some major lbs!!!
Those would be nice, but the labor to transfer the body would be way too much $$$$$
Old Aug 14, 2005 | 02:52 PM
GrandSportC3
Originally Posted by 427Hotrod
Flush mounted Lexan windows since you're racing more than streeting these days.
Planning on changing the windshield and side windows..
Lighter steering column assy.
Who makes a light weight bolt on with the right connector?
Aluminum master cylinder and light brake components you're talking about.
Who makes a bolt on light weight master cylinder? Any links are appreciated... (BTW - I have manual brakes)
Completely block off radiator opening and air coming into engine compartment except scoop.
it's very limited already...
Seal scoop to carb with an aluminum base plate.
That would require fabrication skills that I don't have.. The top of my carb already sits at the same level as the hood.
Open up back of hood/cowl area to make sure no air is trapped under hood. This helps keep nose down at speed.
The cowl is open already.. I cut it open when I installed my home made cold air setup..
Drop nose down to bump stops while at rest.
Need details on that...
Play with high gear timing retard.
I doubt that this is not legal for no-electronics brackets...
I'm really looking for what MPH does in cooler weather. Still looks a little off potential to me.
I'm sure that I can get to 125 mph in winter..
Still not sure on 3/8" fuel lines, bigger is good insurance, especially when you start spraying.
If I'll start spraying, I'm going to run a separate fuel system for the nitrous.. I might go with bigger fuel lines anyway to keep the fuel cooler.. I'll have to pull the sending unit on the tank and have someone install a fitting for the larger line.. Planning on running #8 braided fuel line all the way from the tank to the carb..
Go ahead and plan on 200-250hp N20 hit.
I won't go with more than 150 HP shot because my tranny is only built to 800 HP and I want to be on the safe side... Anyway, 150 HP shot should be good for 9's.. Even with a 250 shot, I won't get into 8's.. so it really doesn' tmatter.
Plastic fuel cell?
When I installed my current fuel tank, I noticed that it's not too heavy.. Don't think that a fuel cell will make a difference...
Very small aluminum race radiator..sell regular one. Less water is lighter weight too!
not worth the money.. My Griffin isn't too heavy and I'm planning on driving the car on the street again at one point and anything smaller will overheat..
I like light control arm idea
me too!!
Check into an aluminum manual rack and pinion set up
That would be too much money considering the weight savings... I'm not going to spend $1000 to save 20 lbs...
Look for someone to replicate your bumpers in chromed plastic.
If I would have somebody fabricate them, it would be way too expensive and not worth the weight savings.. The bumpers are maybe 25 lbs...
Use Royal Purple "0" weight REAL race oil for the banzai runs. This is NOT to leave in for a long time, but it will help turn the number..guaranteed! Not street oil..RACE oil.
I don't wanna take the chance to damage my engine with that oil.. I'm using Royal Purple 10/30 and it works great.
Gotta get those shift points up there.
no doubt.. It's only the 1-2 shift.. I manually shift 2 -3
Set the valves!!
I'll do that when I'll get a chance... The stud girdles should be holding them in place pretty good..
Many small blocks respond to 1.65-1.7 rockers on the outboard cylinders only. That's 4 intake rockers, doesn't cost much.
There are some fuel additivces that will actually increase power, not just resist detonation
I'm pretty sure that the 110 octane leaded fuel has some additives in it.. I'm not thinking in changing out rocker arms.. My 1.6 ratio arms shoudl be fine..
[quote]
Seriously consider whacking heads to get to 13.0 compression with .015 gaskets and go to alcohol. Cheaper than gas, even if you do use twice as much. If you're racing, it just makes sense.
Don't think that this will be necessary.. I only need .15 and most of that I should be getting with the transbrake.. All the suggested weight savings should easily get me .2 or so...
I'll keep trying to think of more....
JIM
Old Aug 14, 2005 | 04:28 PM
Twin_Turbo's Avatar
Twin_Turbo
The Jim Meyers racing kit is set up for coil overs, not some silly monospring deal.
Old Aug 14, 2005 | 04:41 PM
GrandSportC3
Those coilovers look way too short for drag racing.. Drag Race front springs need to be able to extend a lot and those don't look like they'll do that...
I wonder if this ia more like a Road Race rather than a drag race setup
I also looked through the Jim Meyers Catalog and didn't see anything for '68 - '82 Vettes.. just for pre '62...
except:
http://www.jimmeyerracing.com/cv7.html
Old Aug 14, 2005 | 04:58 PM
C3 Stroker's Avatar
C3 Stroker
Check out the Precision Brakes link on the side of the Forum page.....they are making me a bolt-on Wilwood kit with drilled rotors and Dynalite 4 piston calipers for my '69...(I am also trying to lighten my car).....
Old Aug 14, 2005 | 05:03 PM
GrandSportC3
The Aerospace kit is lighter than the Wilwood kit... That's why I'm planning on using the Aerospace kit..
Old Aug 14, 2005 | 05:05 PM
Twin_Turbo's Avatar
Twin_Turbo
too short? what do you wnat? You want the car as low in the front as possible, if it sits high you'll have a pole vaulting type action going on, lifting the nose and squatting the rear..wasting power into the suspension, why would you want long springs that extend? Soft springs yes but long springs? It's not like you're competing in the baha 500.
Old Aug 14, 2005 | 05:10 PM
GrandSportC3
In order to get the most possible weight transfer in front, you need springs that extend a lot.. I'm not talking about springs that make the car sit high, just about springs that have very thin coils and compress easily but also extend easily.. Most drag front springs are rated 250 lbs/inch...
Old Aug 14, 2005 | 05:15 PM
  #33
comp's Avatar
comp
good brake's is allways nice, driver diet is the cheapest,maybe not the easiest but
Old Aug 14, 2005 | 05:18 PM
  #34
GrandSportC3
Well, those brakes are know that they don't really stop too good... :will:.. The stock brakes very likely stop better, but 50 lbs off the front would be nice...
Old Aug 14, 2005 | 05:26 PM
  #35
comp's Avatar
comp
so those are the little 9" rotors with the tiny single piston calipors??
Old Aug 14, 2005 | 05:39 PM
  #36
GrandSportC3
I think that they are 10".. but I'm not sure.. They aren't really good brakes.. but they are light.. I actually if they'll hold the car good enough for the burnout...
Old Aug 14, 2005 | 07:52 PM
  #37
GDaina's Avatar
GDaina
Get a BB Oliver, and junk that mouse....you will be in the low low low 10's, maybe even in the high 9's
Just ask Jim..aka HOtrod427
To What mods?
Old Aug 14, 2005 | 07:55 PM
  #38
GrandSportC3
If I had Jim's engine, I'd be in the mid 9's..
That will be my next setup.. For now, I'm gonna make the mouse kick some azz
Old Aug 14, 2005 | 08:03 PM
  #39
comp's Avatar
comp
look / see if the Super/Stockers (NHRA) run them if not i wouldn'r spend the money ..I'd go up i size and a couple eztra pounds
Old Aug 14, 2005 | 08:08 PM
  #40
Jughead's Avatar
Jughead
Senior Member since 1492
From: Just because I'm paranoid doesn't mean people aren't out to get me...
St. Jude Donor '09
