B/B running temp. ? Help!
Old Aug 14, 2005 | 12:42 PM
monzared69's Avatar
monzared69
Default B/B running temp. ? Help!
I just put a b/b in my 69 vette. Running a new Dewitt alluminum radiator.180 thermostat, new clutch fan, all rad and support seals in place. The car is a fresh 30 over bore. Tri-power set up.The timing is set a 4 deg bttc.It's running hot 210-220 is this normal for a new b/b to break in so hot?
Thanx Mark
Old Aug 14, 2005 | 01:21 PM
zwede's Avatar
zwede
What is the ambient temp when you're seeing 220? What kind of driving? Stop-n-go or freeway?
220F sounds hot to me. My 454 runs 180F (at thermostat). If I drive at low speeds it heats up to 200F where the electric fans come on and it drops back to 180F in a few minutes.
Becool radiator, dual spals, edelbrock waterpump, 50-50 mix dex-cool.
Old Aug 14, 2005 | 02:15 PM
monzared69's Avatar
monzared69
Mostly stop and go. I'm in Fla. it's pretty warm out low 90's.
Old Aug 14, 2005 | 02:19 PM
2th farmer's Avatar
2th farmer
CI 6-8-9 Veteran
My 454 with Al Griffin and factoryish fan/shroud never gets above 190. Even with A/C on stop n go.
Old Aug 14, 2005 | 03:03 PM
L71Maynard's Avatar
L71Maynard
I have a tri-power BB too. Mine runs around 190 when the weather is cool but when it gets above 90 degrees out then mine runs around 210-230 on the interstate or stop and go traffic.
Dave
Old Aug 14, 2005 | 03:36 PM
griffths's Avatar
griffths
Thanx Mark
4 deg initial is what is causing you to run hot at idle. It should be more like 12-16 BUT you should get the Lars tuning paper and set your timing as stated in the paper and let the initial end up wherever. Basically Lars says that 36 degrees with vacuum advance disconnect is where you want to be with all of it in by 2500 RPM or so.
My .02
Jay
Old Aug 14, 2005 | 04:40 PM
73'454folendore's Avatar
73'454folendore
Have a 73' 454 vette and was having the same problem. It was running around 200-220. I adjusted the fuel mixture so it wasn't so lean by tighting it until the engine almost failed and then backed it off 1 1/2 turns. Worked perfect. I never go past the 200 mark but stays steady at 180 even on a hot Florida day. Simple fix it may work for you.
Old Aug 14, 2005 | 04:42 PM
Lasse's Avatar
Lasse
My .02
Jay
My 468 runs max 210 fahrenheit stop 'n' go. Rad/hood seal is very important.
Old Aug 14, 2005 | 07:08 PM
Tom@Dewitt's Avatar
0Tom@Dewitt
Former Vendor
Thanx Mark
1.First make sure your are actually running 220 with an IR gun
2.At least 50 % distilled water
3.Vacuum can functioning
4.Lean fuel mixture (mentioned above)
Old Aug 14, 2005 | 07:16 PM
GDaina's Avatar
GDaina
have a 533 cube tri power car...180 thermostat, stock copper radiator, twin spal fans...doesn't matter what type of driving I do...stop and go or freeway...needle is barely past the first mark
I assume the thermostat is opening all the way, if not, that could be your problem...put the thermostat in a pot of boiling water and see it opens or not.
Old Aug 14, 2005 | 09:34 PM
Swave Dave's Avatar
Swave Dave
Built 468 here . Running about 150 h.p. over stock ; Dual electric fans from a 1990's LT1 Motor set to come on at 200 off at 185. 180 thermostat. 20 degrees initial. Never goes beyond 200 even if I idle it a long time in hot weather. Ill bet also, that, your motor needs alot more initial timing ; go with 75% distilled water and a bottle of water wetter.
Old Aug 14, 2005 | 09:35 PM
Swave Dave's Avatar
Swave Dave
P.S. Make sure your lower radiator isnt collapsing at higher rpms. Check it by speeding up the motor standing still.
Old Aug 15, 2005 | 09:18 AM
CGGorman's Avatar
CGGorman
Good advice up there from all the guys. I can't add anything new, so I'll throw out a "good luck".
Old Sep 4, 2005 | 09:30 AM
monzared69's Avatar
monzared69
Thanx everyone.
I got with Tom Dewitt at Covettes at Carlisle last weekend. My problem was the aftermarket sending unit. I drained my system and replace the sending unit with one I got from him at the show. The car is running 190 degree's now and that's good for a new motor and being in south Fla.
Thanx Tom
To B/B running temp. ? Help!
