Road Course Junkies, Let's compare notes
And I didn't mention the lens-as far as I know it's just a simple wide angle lens with no UV filter.
I'm just not good enough at downshifting yet to make it worth it. Remember, I'm primarily an autocrosser! Actually I'm still trying to make my car easier to heel-toe, from getting the pedals to line up better to getting the carb (or ignition) tuned enough to get a nice smooth blip. I can heel-toe my ZX2 all day long, but the in my Vette it's always been a bitch to do.
BTW, for anyone following along who hasn't caught on, "heel and toe" is a misnomer as the heel doesn't actually have anything to do with the technique other than it's best to lift it off the floor (or heel bar) when braking. Hope you guys who do know don't get tired of me pointing this out to those who may not.
Cool watching you chase that rabbit Jason, but your audio sounded like an SRB off a space shuttle.
Still racing the Mustang. The vette has not been out to play in awhile. Can't afford to put any money into it. I had to get a partner to even afford to race. Construction in socal sucks.
Anyway maybe next season.
Later
You said that you ahd 26.5x9.5x15 on the rear and 25.5x10x15 on the front
But the rear seems much wider than the front
I'm at Infineon/Sears point June 28-29 with NASA. So I will not be at reno. Working on the car to get ready.
ctk30,
The tires in the picture on the back are Goodyear slicks I got from a pro-truck racer way back when. I only used them once. They are on a 12"wide wheel and rubbed the fender unless I maxed out the ride hieght. So I went to the skinnier Hoosiers that would not. I was able to get the hoosiers as take offs from the local track for almost nothing. Since then I bought wheel adapters and ran my Race Car toyo's from the Mustang the last time out. 275/40-17 at every corner. This actually worked very well and if I track the car again I will go with Nitto NT-01, Toyo or some other R compound. I now have the fender flares and can fit nice big tires in there like 69AutoXr. Maybe some Viper tires in 18" or something. Don't know until I get some money! Every penny goes into finishing this season with the mustang. I've learned so much Racing that I would almost have to start over on the vette. Which is good because what i thought I knew, actually is very little. It is nice having a dedicated Race car though. No compromizes.
Anyway if you can get one tire size to work that is a plus. I didn't like the 25.5.10/15's in the rear RPM's were high the tire is pretty short.
Good luck!
ctk30,
Good luck!
But I used one of those calculators and I'm at over 125 at 6800 rpm
I don't think I can get faster than that at sebring
It seems like most vintage racers are running 26.5x9.5x15 in the rear and 245/45/15 on the front
, and buy a decent mount. My home made one that's mounted using a trim screw wasn't rigid enough (imagine that
Took the vette out for some fun 4th of July weekend.
Have not even started the car for more than a Year. Went thru all the fluids and fired it up to go run the Tijuana Grand Prix. Yes' you read correctly Thats in Mexico!!! lol
The shop I have been racing with (JMCMotorsports.com) was taking a few other cars down and asked if I could get the vette down there to put a car in A class. The streets of Tijuana are ruff and the course is more of a Drag Race H.P. set up. We thought the car would do well but what an adventure. First off my setup was way to stiff.
(last run was Nov. 2006 @ Buttonwillow) so I went to work on softening everything. Next we had a power steering hose Failure in qualifying.
Luckily the handy folks that they are in Mexico they made me a hose that would work.
Lastly was Fuel. You can not take fuel into Mexico so I had to drive the car to a Pemex station (public streets) to get (? super unleaded) to mix with the V.P. Race Fuel ($12.00 per gallon U.S. ) they supplied at the track. Thought for sure I was going to get pulled over but nobody cared much, just admired the car. ( In fact the population that came to the track just absolutely loved the vette.) A rivalry had been established between my Vette and a 68 Camero that had raced for many years in this class as the car to beat.
Unfortunately without a Qualifying time and a start from the back I did not have much confidence in the set-up or my chances. As it turned out JMC Motorsports took wins in all classes entered.Here is a couple of pictures of the vette and the video.
There is a wreck on the first lap then just picking off one car at a time until the camero then we have fun!!!
Tijuana Grand Prix 2008
.jpg)
