Road Course Junkies, Let's compare notes
Old Dec 24, 2007 | 05:43 PM
  #541
7t3shark's Avatar
7t3shark
Originally Posted by C3nMe
You're right that sometimes you feel like you never get out of first. The way my car is setup, I pretty much need to shift to 2 on any stretch, and that is still with the 308 in the rear ...maybe it'll be better when the vibration is gone.
Do you have a close ratio 4-spd? Mine is wide ratio w/ a 3:55 rear. Most of the courses didn't have any long straights tho as most of the clubs that set them up ran imports or other low torque/hp cars.
I've done the chalk thing. I don't know that I was clever enough to use all the info it gave me, as I was mostly making sure I wasn't chewing up the sidewall. I did take the tread that is slightly on the sidewall off the rears of the set I'm pulling off, so I think I was running as soft as possible. Maybe you could explain more about how to use that information.
Basically you put the chalk mark starting on the edge on the tread and going over the edge on to the sidewall for about two inches. Do this on three places around the tire. Make a run and if the chalk is gone on part of the sidewall, increase the pressure by about two psi. If not even gone on edge of tread, then drop by two psi. It's been a long time but I seem to remember running high 30s to low 40s.
Don't know about now but Hoosier used to make a good autoX tire. But a smooth driver on street tires can beat a sloppy driver on great tires. I know as when I first started that's exactly what happened to me. Be smooth and consistent is the best way to better times. Have fun.
Base was Whiteman where they now keep the B2s. Awesome airplane.
Old Dec 24, 2007 | 11:33 PM
  #542
69autoXr's Avatar
69autoXr
Here's some of my first in-car video. I also have some autocross footage from Grissom in October coming soon.
Gingerman Raceway, South Haven MI, Oct 13 2007
Old Dec 27, 2007 | 03:24 PM
  #543
burners's Avatar
burners
Cruise-In IV Veteran
Cruise-In V Veteran
Cool video. I hope to have the Vette out on the track in the next month. Getting time to break in the new engine has proven difficult.
Old Dec 27, 2007 | 07:06 PM
  #544
Fastguy's Avatar
Fastguy
St. Jude Donor '03-'05
Next month? Us snow-belt suckers need to wait about four more.
Old Dec 28, 2007 | 02:35 AM
  #545
IronJen's Avatar
IronJen
Abby Normal
Veteran: Marine Corps
JEEZ, that car pulls!
i know from watching my own videos how much slower video generally looks than how it feels.
Old Dec 28, 2007 | 07:31 PM
  #546
NMsharkracer's Avatar
NMsharkracer
From: Formerly from the Great White North but now residing in the Desert Southwest NM (The Land of Dis-Enchantment?)
Chris,
Great video...I've been kinda just watching this thread and it's got me ready to get the '73 back together and get out on the track. Our first NCCC event is in Phoenix later in February before it gets too HOT. I'm finishing the rebuild of the suspension and going to move up from IIIMA/B to RP.
Old Feb 4, 2008 | 09:02 AM
  #547
69autoXr's Avatar
69autoXr
Here's some video of a couple of autocross runs at Grissom Indiana from late October 2007. This was an NCCC event; the course was faster and more open than a typical SCCA course would be like at Grissom. I was on Hoosier A6's. Be sure the volume is on!
Old Feb 4, 2008 | 09:18 AM
  #548
C3nMe's Avatar
C3nMe
That's just cruel! I mean, I can't even get my vette out the garage right now and you're tempting me with the events of the season to come.
I also can't get my vette out the garage since much of the external engine parts are in the basement ...but seriously!
Those are some nice runs ...the video makes it look like those cones are invisible until just before you pass through them -- hope that was a video effect
Now I'm psyched!
Brian.
Old Feb 19, 2008 | 09:06 PM
  #549
Jason Staley's Avatar
Jason Staley
Cruise-In III Veteran
I'm in the process of reviewing data from last falls HPDE at Putnam Park in preperation for my April visit there this year, and thought this might be interesting to you guys. I finally figured out a decent way to overlay my runs from Traqmate over a google earth map of the track. This really highlighted some areas that I need to work on.
1 - I was letting off the gas way too early on the main straight (I already knew this, but its painfully obvious from the data)
2 - I was turning in & apexing too early in corners 1 & 2
3 - I wasn't using the whole track
4 - I was turning in & apexing too early in corners 5 & 7 (90deg turn)
If you zoom in real close, you can see the path relative to the land marks, including the rumble strips at the inside of the corner.
Any other observations, suggestions are welcome.
Old Feb 20, 2008 | 03:32 PM
  #550
burners's Avatar
burners
Cruise-In V Veteran
Jason, that is a very cool overlay. I'm interested in how you did that. I have a G2x that probably outputs similar data. How accurate do you feel the overlay is? It looks to me like you aren't even close to the inside of some of the corners. Is that true or is it the overlay? I'm not familiar with Putnam Park, I assume you are running it clockwise. Overall, very cool.
Old Feb 20, 2008 | 07:28 PM
  #551
Jason Staley
I haven't figured out an exact way of overlaying the data on top of the Google map. I'd say its more of an art than science at this point.
I exported the path out of Traqmate as a GIF file. Then imported it into Google Earth as an overlay. The trick is scaling the GIF image and positioning it on top of the track. I did a best fit using the corners as my guides. I went back and forth between slightly moving the GIF and scaling it until the it fit the best I could get it. I'm sure there are areas that it is not perfect but it does a decent job. I can't move the path in any direction without a portion of my path falling off the course, so I think its pretty close to reality.
As to me not running at the inside of corners 2 and 8. That is true, I didn't get to the very inside of those corners. The instructors at the event actually recommended not going to the inside of turn 8 (the 180 degree turn) and staying about at the center of the track. I tried going closer to the corner a few times, but they were right ... it slowed me down on those laps.
Old Apr 27, 2008 | 03:19 PM
  #552
turtlevette's Avatar
turtlevette
St. Jude Donor '03,'11
racing season bump
Old May 28, 2008 | 11:39 PM
  #553
stlouisvette78's Avatar
stlouisvette78
1st Gear
Ray, your smart strut bracket that cracked,did you get a new one
and box it or did you repair the old one. Pictures welcome. Just saw
cracks in mine at the bolt holes.
Old Jun 1, 2008 | 11:33 AM
  #554
ctk30's Avatar
ctk30
Originally Posted by 72 RAY
Turtlevette,
The tire fit OK statically but with corner loads at speed the fenders would hit for sure. I barely clear the Hoosiers I run. There is no way in the front unless the fiberglass gets reworked.
I'm having pretty good luck with the hoosiers. 25.5x10x15 hossiers TD's up front and 26.5x9.5x15 in the rear. These are on Real racing Wide-5 wheels with adapters, 5" backspace 15x10. Offset trailing arms. They work very well. don't last forever but work great when they are new.
Right now 3500 lbs with me in it. Balance is pretty good and cross weights are pretty good also.
Wider tires in the front than the rear?
Old Jun 1, 2008 | 02:54 PM
  #555
TheSkunkWorks's Avatar
TheSkunkWorks
From: Graceland in a Not Correctly Restored Stingray
Old Jun 1, 2008 | 04:03 PM
  #556
ctk30's Avatar
ctk30
I have mine gusseted so it cant flex
Old Jun 5, 2008 | 01:10 PM
  #557
72 RAY's Avatar
72 RAY
I just repaired mine and then boxed it. Mine cracked at the corner were the metal gets thinner going under the pumkin. (side view). If yours is cracked at the holes I would replace it and then box the new one.
To Road Course Junkies, Let's compare notes
Old Jun 5, 2008 | 04:07 PM
  #558
turtlevette
ray,
have your retired the c3 and still racing the mustang?
Old Jun 6, 2008 | 10:29 AM
  #559
gkull's Avatar
gkull
I have a question. Chris, what kind of camera and lense are you using? What is your max rpm in the video? I also watched your A-X video. Are you getting front end push that is causing the sawing back and forth of the steering wheel?
Old Jun 6, 2008 | 03:22 PM
  #560
69autoXr's Avatar
69autoXr
That's three questions.
The camera was borrowed, but I think it was a Samsung mini DV (tape). The front end isn't pushing-I think you'd be able to see it in the video-it's probably more that my steering is a bit sloppy, bump steer, wide front wheels with shallow backspacing, etc. I'm not sure what my max rpm was in this video, probably somewhere close to 6K. I wasn't trying to wring every last bit out in this video; I'm in a class by myself usually at the track events, so I go out to enjoy myself and make sure I put the car back on the trailer in one piece. In fact when I watch this video I think it looks really slow. I'm much more fond of the autocross video-in that, I am going for every last bit.
