TDC cam timing and distributer
#41
Originally Posted by C3 Stroker
I must have been doing it wrong all along....crank at 12, cam at 6, distributor dropped in with rotor pointed at #1 (NOT #6), and always started in perfect timing....exactly as my manuals say....
#43
Originally Posted by Jclgodale3
can you show me a picture of this engine oil priming tool that turns the components of the motor at the same time? The one "you" use? Very interested...will leave your directed comments in the air for now
The one I use is a Moroso, I think, that has the proper block off for the internals, not just a straight shaft.
My wheat/chaff comment was not directed at you. We seem to agree.
It was a general comment for people to have some idea of the source's validity before they take what is posted as gospel.
#44
With all due respect to Stingr69, #1 and #6 cannot both be at TDC at the same time. If #1 is TDC, then #6 is BDC (BOTTOM dead center) and as far away from firing as possible. Looking at illustrations of cam install instructions, it seems that both scenerios actually achieve the same thing....proper phasing if the cam with the crank. The "dots" are for reference only, not for order. 1-8-4-3-6-5-7-2 equals 6-5-7-2-1-8-4-3....the rotation remains the same and is followed whether you begin with #6 or #1. So, crank 12 & cam 6 position is correct when #1 piston is up (firing position) if you drop in the dist. pointing at #1,.......and both dots at 12 would bring #6 up if you rotated, and you would install the dist. to #6 for correct timing..........BUT, you could also have #6 at TDC (firing) and have the dots line up at 6 and 12, and achieve the same thing- remember, the cam turns at half crank speed, so a 180 deg. turn WITHOUT TURNING THE CRANK when installing your cam would do this and the cam would still be in phase........remember 6-5-7-2-1-8-4-3 equals 1-8-4-3-6-5-7-2...............clear as mud, right?......
#46
Originally Posted by big_G
Dang, this thread is getting sick....I believe on a small block chevy, 2 cylinder are always at TDC at the same time......slap me if i'm wrong......
#47
Question is...Does the original poster, vettepilot68, now have a "clear" understanding?
#48
Umm? YEAH! What he said! It kinda makes all the sense in the world, in an irrational kinda way. But I agree with what you say!
