bad bog when getting on it
Old Oct 3, 2005 | 01:40 PM
camaroneil's Avatar
camaroneil
Default bad bog when getting on it
guys,
i have a real bad bog when i'm giving it more than about half throttle and it changes gear (auto),
it momentarily feels like it's gonna die then it picks back up,
had the carb built by lars about a year ago,
got the timing about right,
while i was playing with the timing the problem was the same all the time even with different springs/weights and vac can,
none of the change in timing settings seemed to make a difference,
anyone any ideas?????
thanks,
natt
Old Oct 3, 2005 | 01:54 PM
69396Chevy's Avatar
69396Chevy
Did it start doing this all of a sudden? When it bogs is it blowing black smoke . . . would mean to much fuel. If its not smoking when this happens I'd say its not enough fuel. Is it just from a stand still or no matter when you punch it.
Old Oct 3, 2005 | 01:57 PM
camaroneil's Avatar
camaroneil
from a standstill it's ok,
it's just when moving,
i've just changed to 3.70 gears from 3.08, surely this can't have made it happen?????
Old Oct 3, 2005 | 02:55 PM
69396Chevy's Avatar
69396Chevy
No gears wont do this. Was it running OK before or has it been like for awhile?
Old Oct 3, 2005 | 03:00 PM
redc3's Avatar
redc3
Accelerator Pump
Old Oct 3, 2005 | 04:03 PM
camaroneil's Avatar
camaroneil
sorry guys,
just realised i haven't explained properly,
it's not as i actually put my foot down,
it's when the car changes gear (auto) i don't actually give it more gas, my foot stays in the same place,
Old Oct 3, 2005 | 04:19 PM
lars's Avatar
lars
Try tightening up the secondary airvalve windup spring. If I set the carb up, it should be set at about 3/4 turn. If it's anything less, re-set it to 3/4. If it's correctly set to 3/4, tighten it to 7/8.
Old Oct 3, 2005 | 04:44 PM
camaroneil's Avatar
camaroneil
thanks lars,
i'll check that in the morning,
natt
Old Jan 1, 2006 | 03:48 PM
renowa's Avatar
renowa
Cruising
Default Bad Bog
Sounds like float level is set too low, when accelerating, in particular after a hard shift (first to second), the momentum causes the fuel in the "quadra-stall" carburetor, to pull to the rear of the fuel chamber. The float is still held closed so no additional fuel enters the chamber, and the jets are starved momentarily until deceleration allows the fuel to return to the jets. Just my guess, but something to consider.
To bad bog when getting on it
