Pulled the Cam/Valvetrain: Results
Old Nov 11, 2005 | 09:04 AM
  #61
hawgn68's Avatar
hawgn68
This is quite the saga. I think it's time to get back to basics. The one issue that leaves me puzzled is the cam install with the timing marks at 6 and 12. While this may be possible (it's too early to think theory through), every engine I've built (that start every time), I install the cam with the crank and timing marks at their closest point at 12 on the crank and 6 on the cam sprocket. Obviously, this is with the #1 cylinder at TDC. The balancer mark should be at about 1:30 - 2:00 when facing the engine. Forget the timing tab, it's just a piece of tin for now.
Without rotating the engine, install the distributor anyway it drops in. Where the rotor is pointing is now your #1 cylinder on the distributor cap. Rearrange your plug wires 1-8-4-3-6-5-7-2 (if you have custom wires, you might have to swap a few out to get enough length). Now rotate the distributor an RCH couter clockwise (advanced) and it will start if you have spark and gas.
I think you've got the cam and distributor 180 out. Good luck.
Jim
Old Nov 11, 2005 | 07:14 PM
  #62
nastee383's Avatar
nastee383
Originally Posted by GDaina
I'm wondering if the rods are hitting the bottom of the cyl. bores
We will soon see. I spent all day today disconnecting everything. Tomorrow the engine comes out for inspection. My worst nightmare is that I don't find anything!
Old Nov 11, 2005 | 08:04 PM
  #63
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
I have seen some weird things like cranks and camshafts snapped in half, but when you turn it over and the ballancer and the rotor are moving then I don't think that's your problem
Old Nov 11, 2005 | 09:56 PM
  #64
David Ey's Avatar
David Ey
"We will soon see. I spent all day today disconnecting everything. Tomorrow the engine comes out for inspection. My worst nightmare is that I don't find anything!"
Could we have a drum roll please?
Old Nov 14, 2005 | 10:42 PM
  #65
BB68Vett's Avatar
BB68Vett
Nastee 383 - So how did it go? Do you have an update? Is it possible that you need a small base circle cam with your stroker? I don't know too much about different types of cams but I have heard in the past that this can be an issue with small block strokers. I've been following the thread. I hope things work out for you.
Old Nov 15, 2005 | 06:21 AM
  #66
nastee383's Avatar
nastee383
I took the motor out Saturday morning. I haven't done anything else yet except rotate it by hand on the stand trying to feel any unusual resistance and listen for any abnormal noises. I didn't notice or feel anything abnormal. I'm currently trying to locate an engine dyno in this area. I want to see if it runs on the dyno in it's current condition before I start disassembly. Plus I can get a read on what kind of power its making if it runs.
Old Nov 15, 2005 | 09:39 AM
  #67
GrandSportC3's Avatar
GrandSportC3
Cruise-In IV-V-VI-VII-VIII Veteran
St. Jude Donor '03, '06, '17
That's a good idea..
Keep us updated and GOOD LUCK!!
Old Nov 15, 2005 | 12:58 PM
  #68
69autoXr's Avatar
69autoXr
That sounds like an expensive way to see if it runs!
Old Nov 15, 2005 | 01:44 PM
  #69
norvalwilhelm's Avatar
norvalwilhelm
I would degree the cam first. It is a simple procedure and takes little time. If it is in properly with spark the motor should run. D
You do NOT need the distributor in the car to check spark. Hook everything in the ignition up and turn the distributor by hand. Spin if freely in the air with a plug on the ignition coil. It will spark like normal.
Rods or anything hitting will NOT cause the motor not to start. It would start and just rattle.
Degree the cam first.
Old Nov 16, 2005 | 04:47 PM
  #70
JAMZILLA's Avatar
JAMZILLA
One of 2 things either that engine is not getting fuel or spark.
Otherwise it would Kicbback Or backfire or flame the carb. No question and I also
Old Nov 17, 2005 | 08:03 PM
  #71
nastee383's Avatar
nastee383
Haven't done alot this week. I get off work relatively late. But I did pull the oil pan to take a look around. I rotated the motor and visually observed to see if anything was scraping, bent or otherwise messed up. It all appears fine. In fact, the motor looks darn good, H-beam rods, 12 point ARP hardware, clearancing on the pan rails, etc, etc. This was a quick 20 minute or so check but I plan to be more thorough this weekend and take some pics.
The pressure is on now because I pre registered for the Power Tour today and this vehicle IS going with this motor in it.
Old Nov 17, 2005 | 08:23 PM
  #72
GrandSportC3
I can't wait to hear what the issue is that caused the engine not to start..
Old Nov 17, 2005 | 09:37 PM
  #73
David Ey's Avatar
David Ey
My money is on We'll never know"
Old Nov 17, 2005 | 10:23 PM
  #74
big_G's Avatar
big_G
Old Nov 18, 2005 | 07:43 PM
  #75
nastee383's Avatar
nastee383
That's a real possibility. But if it starts when it goes back in that'll be enough for me.
Old Nov 29, 2005 | 09:32 AM
  #76
David Ey's Avatar
David Ey
UP-date ?
Old Nov 29, 2005 | 11:13 AM
  #77
big_G's Avatar
big_G
This is one for "Unsolved Mysteries".....Anyone have Robert Stack's phone number?
To Pulled the Cam/Valvetrain: Results
Old Nov 30, 2005 | 06:21 AM
  #78
nastee383's Avatar
nastee383
UP-date ?
Nothing worth posting. Work, both kids playing BBall for the high school, wife taking me shopping on the weekend, hospital appts, etc. Not leaving much time to do anything significant.
Old Nov 30, 2005 | 08:47 AM
  #79
theandies's Avatar
theandies
I'm with Norval, Degree the cam and see what happens.
Old Dec 6, 2005 | 11:32 PM
  #80
moosie982's Avatar
moosie982
UP-date ?
Have I missed the solution??? Peace,,,Moosie
