Pulled the Cam/Valvetrain: Results
Old Dec 24, 2005 | 09:44 AM
  #101
turtlevette's Avatar
turtlevette
St. Jude Donor '03,'11
Originally Posted by norvalwilhelm
It's not alot of BS crap. The cam is 180 degrees out of time .
I don't see how the cam can be 180 out. As long as the timing marks line up every other rotation of the crank its installed properly.
On the first time the marks are at 6 and 12 and the first revolution of the crank they are at 12 and 12. How is there any other way to do it.
He's got 200 pounds of compression.
Old Dec 24, 2005 | 09:50 AM
  #102
mandm1200's Avatar
mandm1200
Jimbo you are right as before. The cam is 180 degrees out of time.
That's almost impossible. For the cam to be 180* out of time, the crank would have to be 12 and the cam at 3 or 9.
If the crank is at 12 and the cam at either 6 or 12, then its correct. The only thing that could be 180* out of time is the distributor.
There is a huge difference between a cam being 180* out of time versus the distrubutor being 180* out of time.
Old Dec 24, 2005 | 10:08 AM
  #103
norvalwilhelm's Avatar
norvalwilhelm
The cam sprocket only bolts on one way. If you install it so the timing mark is at 12 and it should be at 6 the cam is 1/2 turn out. 1/2 turn of 360 degrees is 180.
Old Dec 24, 2005 | 10:11 AM
  #104
norvalwilhelm
You have a very good point there Turtlevette. The cam only bolts on one way, has a dowel pin so the sprocket is on correctly. Bring the crank sprocket mark to 12 and you install the cam mark at 6 but like you say every other turn in is aligned at 12 and 6.
He has 200pounds of compression??
Have to rethink what I have be thinking.
You win this round turtlevette
Old Dec 24, 2005 | 10:17 AM
  #105
turtlevette
:o That'll never happen again.
Old Dec 24, 2005 | 01:27 PM
  #106
hawgn68's Avatar
hawgn68
The cam is 180 out with the distributor if he's trying to fire #1 with the cam at 12 and the crank at 12 (like his posts indicate). Put a sprocket on an old cam and look at the lobe profile with the timing mark at 12. The exaust just closed. He'll still get compression, but firing after the exhaust stroke. All he needs to do is put the #1 plug wire where #6 is now, and move the rest of the wires in order.
Jimbo
Old Dec 24, 2005 | 02:11 PM
  #107
The_Dude's Avatar
The_Dude
St. Jude Donor '11, '16-'17
It's impossible for the cam to be 180 degrees out of time, if it was installed with the mark at 6 or 12.
Old Dec 24, 2005 | 03:30 PM
  #108
David Ey's Avatar
David Ey
but the dist. could be wrong and if you are feeling for compression by using the starter you MIGHT feel a bit on the exhaust stroke and be mistaken. Rotate the motor s l o w l y.
Old Dec 24, 2005 | 03:48 PM
  #109
norvalwilhelm
To drop a distributor in I slowly turn the motor over while watching the number one valves. I watch the exhuast open close, the intake open and close and then bring it to about 10 degrees before TDC. I already have the distributor housing marked where number one plug goes so I install the distributor body with the rotor pointing to #1 mark on the housing,
Old Dec 24, 2005 | 05:15 PM
  #110
jetvette's Avatar
jetvette
I read in awe the knowledge shared in the Forum. I am also pleased to see two very fine contributors accept another's solution and own up to their occasional lapse. Thanks to all contributors who also force me to think these things through. I cannot possibly contribute more to this issue than has already been said, but I continue to learn and offer my respect to all.
Old Dec 26, 2005 | 06:29 PM
  #111
nastee383's Avatar
nastee383
I have a question for you guys that say the cam is 180 degrees out. The question is: If the motor was running fine and I had a starter kick back (from too much initial timing) and it ran after that but got progressively worse until it wouldn't start again, how did the cam get 180 degrees out if the motor was running?
Also, when I took it apart and reinstalled it I put the #1 piston at TDC and installed the timing chain at 12 crank and 6 cam. Why would that make the cam 180 out?
I'm not being a smart aleck but ya'll are confusing me. I've taken my Vette motor apart several times and installed the timing chain in the same manner and it runs like a champ.
Old Dec 26, 2005 | 07:01 PM
  #112
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
Cam can't be 180deg out only the distributor, that can be any amount out depending on where it is pointing when you at 0 deg on the balancer.
The crank gear is keyed and the cam gear has a hole that fits over the peg on the end of the cam. Forget about this 12 and 6 or 12 and 12 BS. It can be either way, if it is 12 and 12 the next time the cam comes around it is 12 and 6. The important thing is, when it is 12 and 6 make sure the dots line up everything else will take care of itself, it can't be on the wrong stroke etc. because of the keyway on the crank and the peg on the cam make it so everything lines up.
  #113
David Ey's Avatar
David Ey
Originally Posted by nastee383
........ but got progressively worse until it wouldn't start again, how did the cam get 180 degrees out if the motor was running?.
Something could have been slipping.
It wouldn't.
Nas, we aren't being smart either. We just want to see it fixed. If all the things have been like you have said in the past month or so something is slipping. Something like a bad crank key or dist. gear on cam or dist. Is your cam one piece or is the gear a seperate piece pinned on it? Have you removed the roll pin holding the dist. gear on to verify it is not sheered? Remove the dist gear and pull the shaft out and closely inspect it on Both ends. Do you still have the screetch sound when you crank it?
Old Dec 26, 2005 | 11:19 PM
  #114
GDaina's Avatar
GDaina
And that's when you drop in the distributor with the rotor pointing to the #1 plug wire. Then and only then everything will take care of itself....
Old Dec 27, 2005 | 01:14 PM
  #115
David Ey's Avatar
David Ey
Old Dec 27, 2005 | 06:46 PM
  #116
MotorHead's Avatar
MotorHead
That's true but most of the time it is not done that way. Look at crate motors with no distributors, or when you get a motor back from a rebuild etc. Most of the time you will still need to find TDC on the compression stroke for #1 then stab the dist. and yes magically under the timing cover the dots will be lined up
When I said everything will take care of itself I meant, when you line up the 2 dots the cam and crank will be in the proper positions. Because of the keyway in the crank and bolts and peg on the cam you can't mess it up, it is idiot proof.
Old Dec 28, 2005 | 08:54 AM
  #117
GDaina's Avatar
GDaina
Why not? And why not do it this way? Adjust the valves while on the stand, line the two dots, install the timing cover and the balancer, drop it in the chassis, drop in the distributor. Works for me every time. I don't mess with finding the compression stroke, I know it will fire, just a question of advance or retard.
To Pulled the Cam/Valvetrain: Results
Old Jan 29, 2006 | 09:15 AM
  #118
sly vette's Avatar
sly vette
It's been a month since last post, has anyone figured this out yet?
Old Jan 29, 2006 | 10:28 AM
  #119
sweethence's Avatar
sweethence
From: Wilmington DE, Drive it like you stole it, 68 327 4 speed coupe
Default try this
with that much advance, you need to make sure that as you set mechanical lash on the valve train you do it with the intake and exhaust valves both closed, which will be 8 degrees off from TDC. if you set the valve at TDC your valve train will not be set right in some cases the valves will be set on the rising slope of the cam in other the falling. the result is i beleive what yoou are seeing. ive seen this proble before though is different circumstances. and the engine wont fire.
tim
Old Jan 29, 2006 | 12:59 PM
  #120
nastee383's Avatar
nastee383
Hasn't been much to post. I do have a date with the engine dyno scheduled for Feb 4th. I'll find out something right off the bat...whether its gonna start or not. If it does, I guess it something in the ignition/starter circuit on the vehicle.
