Engine Temp
Old Nov 21, 2005 | 09:09 AM
rihwoods's Avatar
rihwoods
Originally Posted by kb2fzq
VERY COOL!!!
I will definately take your advise...thank you very much for your patience with me and my questions....you've helped a bunch!!!
Bill
My pleasure...let us know what you find...
Old Nov 24, 2005 | 06:16 AM
AlCherry's Avatar
AlCherry
The conditions are: 55-65 mph, 185-190 F, 70-75mph 210 to 220 F. Cools back down when I slow down. Pulled the thermostat yesterday, seems to be ok (180) (stuck it in hot water). I don't know if the electric fan is kicking in. I have to change the fuel pump today, so I'll R&R the radiator and flush the system, see where it takes me.
Old Nov 24, 2005 | 09:49 AM
ESU's Avatar
ESU
VERY COOL!!!
Bill
Kb2,
Check out this thread, the topic is covered fully from one end to the other,
ESU
http://forums.corvetteforum.com/show...post1552874547
Old Nov 24, 2005 | 09:50 AM
ESU's Avatar
ESU
I'm in the same boat as you temp wise, I can even go higher with the a/c on and 95 deg day. Everything rebuilt and/or changed but to no avail.
ESU
Old Nov 24, 2005 | 11:39 AM
AlCherry's Avatar
AlCherry
Thanks for the info. Gotta get out there and get er done.
Old Dec 4, 2005 | 07:42 AM
AlCherry's Avatar
AlCherry
Default Update on engine temp
Tore into engine compartment, replaced waterpump, fuel pump, all hoses, had radiator repaired, replaced core support that was badly rusted. Got it back together, put in a 50/50 mix of anti-freeze.
The wife took it out and leaned on it (NEVER tell the wife to lean on it) and it ran at max 210 F with both fans on. Before it was 240F+. At cruising speed it runs 180-190F. Thanks for ya'lls help.
Old Dec 4, 2005 | 09:12 AM
DR.Jay's Avatar
DR.Jay
Originally Posted by randyredleg
Mine stays centered on the "2" in "200" under normal driving, but when I drive up a small mountain range it creeps up so the needle is on the middle "0" in the number "200" . If I accelerate , I get a light knock. Sounds like shaking small gravel in a tin can. Does this sound like a carb or a timing issue? Radiator and hoses are new.
The knock is caused by pre-detination (spark knock). This is can be caused by carbon build up in the combustion chamber, bad timing, low octane fuel. I would try running on a higher octane fuel first, if that doesn't cure the problem, check your timing. Another good cure is a water injection system it helps alot. It did wonders for my wifes suburban with high miles. I even noticed a change in eg temp after the install.
DR. Jay
