Where's the grounds?
Old Dec 12, 2005 | 07:12 PM
Jclgodale3's Avatar
Jclgodale3
Default Where's the grounds?
Ok...have the ground from the battery to the frame (directly under the battery) Also have the ground from the engine to the frame. Where else should it be grounded? While starting it the other night a friend noticed an arc jumping from the dipstick handle to the power brake booster. And the handle was getting HOT! Assumption is...it's trying to find another ground. Never had a problem with it starting but don't want to start a fire under the hood either!
Input or suggestions?
Old Dec 12, 2005 | 07:21 PM
shafrs3's Avatar
shafrs3
Maybe your existing ground connections have corroded or loosened? That’s all the ground connections I have on my ’72.
Old Dec 12, 2005 | 07:24 PM
Jclgodale3's Avatar
Jclgodale3
So there is NO other grounding point? Just these 2?
Old Dec 12, 2005 | 07:28 PM
shafrs3's Avatar
shafrs3
Not to my knowledge.
Old Dec 12, 2005 | 07:50 PM
LYLE's Avatar
LYLE
Their is one from the # 1 body mount to the frame and I think it is on the drivers side. It is too small to use for the starter.
Old Dec 12, 2005 | 07:56 PM
Z-man's Avatar
Z-man
There is also a black ground wire from the main harness to the starter motor. It usually has an eyelet on it.
Another ground can be found from the antenna to the frame in the rear of the car (but that one just grounds the antenna - not electrical battery voltage).
I suspect the sparks you saw the other night were weak spots in your spark plug wires. The spark was jumping to ground instead of to the spark plug (which would make it harder to start).
Old Dec 12, 2005 | 08:05 PM
Jclgodale3's Avatar
Jclgodale3
No...the plug wires are new. The spark was definetely coming from the handle on the dipstick to the booster. Hence the reason the handle was getting so hot. Or, are you saying a plug wire touching against the dipstick tube?
Old Dec 12, 2005 | 08:29 PM
SteveG75's Avatar
SteveG75
Check the ground from the engine to the frame by the passenger side mount. That is the only ground from the engine to the frame.
Old Dec 12, 2005 | 08:30 PM
Jclgodale3's Avatar
Jclgodale3
I'll recheck that one...thanks
Old Dec 12, 2005 | 09:22 PM
David Ey's Avatar
David Ey
If you have ONE GOOD GROUND you will not have an arc from dipstick to booster. It just won't happen. If you have a bad plug wire I would be really surprised if you have enough energy to spark from wire to dipstick (which is a ground itself) and also continue a spark to the booster.
Old Dec 12, 2005 | 09:39 PM
corvetteatv7's Avatar
corvetteatv7
But if his coil is putting out above 20000 volts like it should be then it might be possible.
Old Dec 12, 2005 | 09:43 PM
Jclgodale3's Avatar
Jclgodale3
the dipstick handle...when istalled properly is about an 1/8" from the booster
Old Dec 12, 2005 | 09:55 PM
David Ey's Avatar
David Ey
Yes, but isn't the dipstick grounded to the block?
Oh well, who knows whats going on here. Looks like another mystery like the why won't my 383 start when it has gas, spark and compression and the valves are working in time with the crank and the dist is set close enough.
Old Dec 12, 2005 | 10:08 PM
corvetteatv7
thats one of those, its not that complicated, yet it won't work type of things. its a combustion engine, not rocket science, yet they produce some weird mysteries sometimes.
Old Dec 12, 2005 | 10:53 PM
Lohkay's Avatar
Lohkay
Lol... Check for a cloth covered ground wire between the frame and the body skeleton near the first mount on the driver side. That should ground your body. Then you have the one for the engine like the others said... with both of those covered, you can move on to another reason for that spark... I've never heard of plug wires jumping like that though.
David: gas and spark ignite if there is combustion, whatever your timing is. If its not even puffing or huffing then you don't have one of the 3 said above. If it is puffing, then play with the timing (Maybe you have your dist. inversed, happens often). To know the dist is in the right spot, put piston #1 at TDC on the compression stroke (Valves closed) and open your dist. It should point at your #1 cable. If its pointing opposite, you got it inversed.
Old Dec 13, 2005 | 06:17 AM
kb2fzq's Avatar
kb2fzq
Shouldn't the spark jump while the car is running in this case?...not just while starting?? I thought he said it happened "only" during start-up...Sounds of ground problems to me..
Old Dec 13, 2005 | 09:04 AM
David Ey's Avatar
David Ey
Thanks guys, but I was refering to nastee383's no start problem. Mine runs great
To Where's the grounds?
Old Dec 13, 2005 | 02:41 PM
Z-man's Avatar
Z-man
That's what I was thinking. Plain old 12volt from the battery isn't enough to jump across even a 1/32in gap. To jump that far requires the high voltage from the coil. How close was the booster?
Old Dec 13, 2005 | 04:16 PM
bobs77vet's Avatar
bobs77vet
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
sure sounds like arcing from a spark plug wire
Old Dec 15, 2005 | 01:28 PM
shafrs3's Avatar
shafrs3
When you find your gremlin, please let us know what you found.
