$6000 wow ill be way under that ,more like $1500 you need to search for the deals.
go to ls1tech.com youll find some good deals on there.
$1500...I'm liking that. Though I think it might be more since I'd want an engine that has at most 30,000(want to keep it close to the actual miles of the vette, but I wouldn't mind going lower). Thanks for the link, I'll check it out right now. Did anyone ever put an LS6 in a C3?
Originally Posted by 70 LS1
Here is a rough list I made up. Be prepared to spend around $6K.
I skimmed through your site. First of all, let me say very nice corvette. Your write up is also great. I can tell that it will be helping alot on my project(hopefully).
oh ok since my block was brand new and the heads,cam,crank pistons and rods had only 2000 miles from a 04 vette,new file to fit mahle rings,Ls6 intake,new ls6 oil pump,new cloyes chain and some brand new parts like front cover,valve covers etc...So really its pretty much brand new.
LS6 = LS1 with different heads and cam. It's pretty much the same swap. (Since I put the red Z06 covers on the engine, I usually tell people it's an LS6.
Since i already had a tpi setup and i used a walbro 255 intank pump im staying with that havent decided on what im doing for a regulator yet.NOt sure what the other guys are doing.
thanks buddy,ill be finish welding mine at work tomorrow,i only had time this morning to work on my crossmember since i had to move the trans forward i figured why not make the middle of it removable.Can you send me a pic of the spacer you did for the steering to clear the pan.
Im planning on getting a ls2 402 short block set up for 8.5:1 compression with some beefy internals and building it up into a turbo motor. Im leaning towards twin turbo now but havent ruled out a big single either. Im still in the planing stage right now. Im waiting on a couple of quotes for the short block and still have a huge amount of work to do on the car to bring it up to what I want. I decided to go with flares and some real wide 18" rims. Im going to pull the body and replace the rocker channels and por15 everything. Im looking forward to starting on the engine in the next couple of months.
Sounds like a nice setup keep us posted and take pics.
Does any know if I'd be able to use my side exhaust with an LS-1? I doubt it, but there HAS to be a way inorder to make it work, right? Them pipes are so damn sexy.
