pulling heads
Old Mar 5, 2006 | 09:13 PM
Markm10431's Avatar
Markm10431
Parrothead
St. Jude Donor '08-'09,'13, '14
Default pulling heads
if you pull the heads do you have to mill them? I have a shop saying they wont get the heads to seal if they pull them off the block without milling.. Sounds like to me but I'm no expert
Old Mar 5, 2006 | 09:16 PM
oregonsharkman's Avatar
oregonsharkman
I have put them back on with a good scrape job and some new gaskets with no problems.....however milling is cheap and probably wouldn't hurt......then again I'm not an expert engine builder
Old Mar 5, 2006 | 09:35 PM
dgruenke's Avatar
dgruenke
I think as long as you scrape the old gasket off well and torque the bolts in a star pattern, the heads should reseal just fine.
Old Mar 5, 2006 | 09:40 PM
ZL1powr's Avatar
ZL1powr
If the surface is flat milling is not required. I have re-installed heads many times without milling and have not seen any issues with sealing. As said above just make sure they are clean.
Old Mar 5, 2006 | 09:46 PM
lars's Avatar
lars
That's . As long as there is no damage to the heads, the heads can be removed and installed indefinitely.
Old Mar 5, 2006 | 10:18 PM
63mako's Avatar
63mako
If they are not warped they can be reinstalled without milling. If they were not having problems when removed they are probably fine. Easy to check for warpage. After they are cleaned use a straight edge from one end to the other with a light behind it. If they are warped enough to require resurfacing you will be able to tell.
Old Mar 6, 2006 | 10:01 AM
kevinator80's Avatar
kevinator80
Lay the straight edge on the head and use a feeler gauge to check for gaps. I am not sure what the tollerance is but .001 should be ok?
Old Mar 6, 2006 | 12:37 PM
Jims79's Avatar
Jims79
I have a question. Why are you pulling the heads in the first place? If you are going to rebuilt or replace w/better heads then why not mill them? .02
Old Mar 6, 2006 | 01:04 PM
Ed Blue 03's Avatar
Ed Blue 03
Not unless they need it.
Old Mar 6, 2006 | 06:51 PM
Markm10431's Avatar
Markm10431
Parrothead
I'm debating between a rebuild and a crate engine. I have to have the intake worked on and the throttle body cleaned, and I wanted the shop to pull the heads, inspect the cylinder walls and valves. I have massive vacuum problems from somewhere along with the coolant smell in the exhaust.
To pulling heads
