Conversion possible from MSD to mechanical tach?
Old Mar 13, 2006 | 12:07 PM
gavanm01's Avatar
gavanm01
Default Conversion possible from MSD to mechanical tach?
In building my 454 stroker the distributor will be changed out for a MSD set up. I need some ideas on converting my 1969 tach to electric, if possible. Is there some sort of electro-mechanical conversion kit or will I just have to live with an extra electric tach somewhere else in the cabin? Thanks in advance for any replies to this challenge.
Old Mar 13, 2006 | 12:16 PM
zwede's Avatar
zwede
You should be able to find some info with a search. Several of us have replaced our mech tachs with 75-77 electric tachs. I used my 71 faceplate so the numbers are the correct color and redline is correct. It's a fairly simple procedure.
Old Mar 13, 2006 | 12:22 PM
gavanm01's Avatar
gavanm01
I was hoping for a solution that did not require taking out the dashboard; not a fun thing. I reckon your conversion requires this, correct?
Old Mar 13, 2006 | 12:52 PM
theandies's Avatar
theandies
Are you just trying to get rid of your mechanical tach? MSD makes a tach drive distributor. Thats what I am running.
Old Mar 13, 2006 | 01:12 PM
JoeRags's Avatar
JoeRags
I have an MSD Pro-Billet with a mechanical tach drive in my '70. Forgot what the part number was, but look around. Worked great for me..... until my tach cable broke. now I have no tach.
Old Mar 13, 2006 | 01:44 PM
b71vette's Avatar
b71vette
I have an MSD Pro Billet Mechanical Tachdrive in my 383 stroker part#8571, I believe it fits a big block as well.
To Conversion possible from MSD to mechanical tach?
