Let's talk spreader bars...
Old Mar 29, 2006 | 09:02 PM
  #41
Eddie 70's Avatar
Eddie 70
Ci 6, 8 & 10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
Originally Posted by wnjlt1
good job Eddie 70
Thank ya, thank ya very much. It really is an easy install and can be done in less than an hour.
Old Mar 29, 2006 | 09:25 PM
  #42
Eddie 70's Avatar
Eddie 70
good job Eddie 70
Old Mar 29, 2006 | 09:37 PM
  #43
Bimmervet's Avatar
Bimmervet
St. Jude Donor '12-'13-'14-'15-'16
Default Front bar
I have a 79 vett with the Vette Brakes Bar. I had it welded on and I use an Elderbrock Alloy Water Pump with stock fan no problem. This was the biggest bang for the buck.
Old Mar 29, 2006 | 09:39 PM
  #44
Yellow73SB's Avatar
Yellow73SB
St. Jude Donor '07
I wonder if I could increase camber gain by putting tension on the shock towers.
Old Mar 30, 2006 | 12:09 AM
  #45
LiveandLetDrive's Avatar
LiveandLetDrive
A little but not nearly as much as lowering the inner mount, raising the outer (at the upright), or shortening the A-arm. I wouldn't want to put those stresses in the frame/bolts.
-Chris
Old Mar 30, 2006 | 07:20 AM
  #46
b71vette's Avatar
b71vette
Just received my pre-welded spreader bar from VB&P. Brackets would not fit either side. the pre-drilled holes did not line up with control arm bolts and one of the bracket tabs was welded on at an angle. Gonna be calling VB&P and asking for a new set of brackets. Other than that they look sweet. But a tad disappointed.
Old Mar 30, 2006 | 08:38 PM
  #47
rclinton's Avatar
rclinton
Veteran: Marine Corps
Default 80 L82 spreader bar fit
Did some looking under the hood to see if the spreader bar will fit with the stock L82 fan shroud. No way will it fit positioned over the front A arm bolt. The fan shroud is right in front of the nut. Not sure how far back towards the rear A arm bolt the spreader bar can be moved. Anybody else run into this setup problem? I would like to keep the fan shroud and the spreader bar but dont want to throw $80.00 away if it just aint gonna fit.
Old Mar 31, 2006 | 07:34 AM
  #48
GUSTO14's Avatar
GUSTO14
Bob,
You're welcome to take a look at mine to see how it's installed and compare it to your engine compartment. I have it in a stock '73 with L-82 and everything fits fine. I bought the un-welded kit and mocked it up in the engine compartment, marked locations and then had it welded. A little paint, then install and it clears everything.
PM me if you'd like to compare notes...
GUSTO
Old Mar 31, 2006 | 08:32 AM
  #49
rclinton's Avatar
rclinton
Default spreader bar fit on 80 L82
Thanks, If you got yours to fit with the L82 shroud Im sure it will fit in mine. Just looking at all the other pics then looking at mine there is no way it was going in the same location. Will be a few weeks anyway....car goes in the paint booth today for the primer then next week for the color. thanks again for the offer. Bob
Old Mar 31, 2006 | 08:44 AM
  #50
b71vette's Avatar
b71vette
Update: I spoke to VB&P on Thursday , they are going to test fit a new set of brackets to make sure the holes line up and then ship them out to me. They jumped on this really quick.
Did anyone out there have any issues with the holes not lining up on their pre-welded kit ?
Old Mar 31, 2006 | 08:52 AM
  #51
evalu8r's Avatar
evalu8r
Can someone measure the center bar for me? I'm going to fab my own. The parts total are about $30 at Speedway.
Chris
Old Mar 31, 2006 | 08:56 AM
  #52
norvalwilhelm's Avatar
norvalwilhelm
Chris
My center bar is only 16 inches but it depends on your mounting.
I also bought my parts from Grisdale racing and they are cheap
Old Mar 31, 2006 | 09:01 AM
  #53
DC118us's Avatar
DC118us
Wow, only 16 inches? So one of the speedway 18 inch bars, with heim joints would do it? I was thinking it was wider than that, but I hadn't measured to verify......
Great info.....
Old Mar 31, 2006 | 08:24 PM
  #54
Older Than Dirt's Avatar
Older Than Dirt
I received my spreader bar today. I saw your post about the brackets not fitting properly so I test fitted mine to see if they were ok. They fit perfect. Maybe yours were made on a late friday evening near quitting time and the worker was in a hurry to get to the beer store.
Old Mar 31, 2006 | 08:30 PM
  #55
Older Than Dirt
Chris
Fully retracted.....center to center of heim joints......19 1/4".
Old Mar 31, 2006 | 08:36 PM
  #56
Yellow73SB's Avatar
Yellow73SB
St. Jude Donor '07
He wants only the center bar length that connects the heim's.
Old Mar 31, 2006 | 08:57 PM
  #57
evalu8r's Avatar
evalu8r
Na that's good. I just wanted to make sure the 18" bar from speedway motors would work. Thank you
Chris
Old Mar 31, 2006 | 09:56 PM
  #58
cherrybomb78's Avatar
cherrybomb78
Originally Posted by GUSTO14
I installed one from VB&P in my '73 back in the early 90's as an all out effort to improve my cars autocross manners. I did this along with lowering, upgrading to complete F-41 suspension, polyurethane bushings and new shocks. When I installed the spreader bar, I set the adjustment with the weight on the wheels. At this point I could quite easily twist the bar about the Heim joints by hand. I later lifted the car (front wheels off the ground with suspension fully extended) via the front crossmember. I happened to grab the bar and noticed that I could no longer twist it by hand; it was under that much tension. I would not have believed that the front suspension flexed that much, but apparently it does.
I guess you could always measure the distance between the two top a-arm cross shafts with the weight on the wheels and then pick it up via the crossmember and measure it again. I would not be surprised to see half an inch or more…
Good luck… GUSTO
Can anyone tell me exactly where to look for these cracks that can occur?
