BB alternator lower bracket w/o power steering
Can anyone address the question as to the application of the lower bracket for the alternator on a 69 big block without power steering. Specifically, the part made for autos without power steering is discontinued. Can a big block lower bracket with power steering be substituted? The plan is to add power steering next year anyway, but a not certain I can substitute one for the other. This is for a 454 big block going into my '69 coupe. Any advice will be appreciated.
69`s still have the short waterpump so you should be able to use the stock cast iron bracket that bolts to the left cylinder head. Early BB Camaros use the same bracket.
Thanks for info; please confirm we are talking about the lower alternator bracket. I'm trying to see what difference a short or long water pump has to do when ordering the lower alternator bracket for a big block with no power steering. Am I missing something?
I ordered one today from Billett Specialties. Summit has one as well. I really wanted one that would fit the driver's side but it was only offered in small-blocks. I like the way it mounts in front of the head instead of outboard on an arm with a brace bolted to the header.
You guys are not listening. 396/427/or 454 ect, in early Vettes, through at least 1970 use a short waterpump and there is no lower bracket, just the one that bolts near the front on the head by #1 plug. This is a factory bracket that works only with the short WP and pulleys.
I'm not aware of a lower bracket
Like this one ??? Have power steering,though...
Rich
Pic of lower bracket WITH powering steering....maybe this will help ID one without PS...???
Rich
Now you're cookin' with gas. That's a lower bracket for the alternator with a power steering option. I wonder, what difference does it really make whether you have power steering or not? A bracket is a bracket, ain't it? Wouldn't the bracket for a power steering option work on a car without power steering?
Ok..found out ZIP has lower alt bracket for 427-454 WITHOUT power steering....Part no. M-2299....$47.50..
I purchased my lower alt bracket w/power steering from them...$60....part M-2363,as shown in pic above...page 105 in their catalog...
Rich
Rich
Rich
Update: Zip shows the product discontinued, as do four other vendors I've called today. None in stock. I may go ahead and cast my fate to the wind and try the bracket with power steering option for giggles and grins. Will let you know... Thanks again guys.
The waterpump is not the short one for a correct 69 BB engined car. Therefore brackets may be somewhat hard to find. However original 69 parts would work with changing to the the short waterpump. Or, try 73 Chevelle`s BB`s parts as they use the long waterpump.
