Comp Cam XE262
Old Mar 29, 2006 | 12:48 PM
tapio's Avatar
tapio
Originally Posted by lars
I installed that cam in a 327 I built for a friend of mine's wife's Camaro. It's a very mild cam, it idles about like a stock cam, and makes the car very easy to drive. It did produce a noticable performance improvement over stock using the stock heads - it has excellent low-rpm torque and makes the car feel strong through the mid-range. It flattens out over 5000 rpm.
I agree.
Old Mar 29, 2006 | 12:53 PM
Kid Vette's Avatar
Kid Vette
Here's an interesting comparison of the XE262 to the XE268. Dyno sheets are from Comp Cams web site.
The XE 262 actually produces slightly more HP and torque than the XE 268 with this engine setup.
Old Mar 29, 2006 | 01:01 PM
lars's Avatar
lars
CompCams used Dart heads and headers on their test mule engine. This makes a huge difference over the stock setup.
Old Mar 29, 2006 | 01:53 PM
bobs77vet's Avatar
bobs77vet
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
can't argue with those graphs.....makes you wonder why someone would choose the 268.....ooops that was me......i think that the difference is so slight in the grinds that on either side of any cam the next choice is very similar....an i do like the 268 so looks like the 262 will work well for you if you want to be around 350hp
Old Mar 29, 2006 | 06:27 PM
marshrat99's Avatar
marshrat99
Originally Posted by VintageMuscle
Is that with iron heads? What octane fuel is required? and does it take all the timing?
The heads are iron. They're Dart Iron Eagles.
I've only run 93 and suspect that 87 or 89 might be a problem. One time I did put a couple of gallons of 89 in, just enough to get me from one service station to another since the first was out of premium but only had to go 4-5 blocks.
My timing is standard Lars. 36* all in by 2,500 RPM.
Old Mar 30, 2006 | 09:34 AM
73jst4fun's Avatar
73jst4fun
Bob, That's what sold me on using that cam also the Comp Cams graphs, we were surprised with the low numbers, that's why I'm switching Bob, disapointed with the performance, great mild cam for the street though, no lope smooth idle, low end and mid range torque pretty good, after that it falls off...youv'e seem my 73 Bob, next 2-3 weeks new engine will be installed....
Old Mar 30, 2006 | 09:36 PM
Taijutsu's Avatar
Taijutsu
Default First Engine
I drove my 74 w/M21, 327 too much cam, fulie heads, stk intake and redone q jet. After 95K it was time for rebuild. TFS heads, 650 Demon vs, 218-224 HR + 1.6 RRs = .532 I / .539 E. Went to dyno w/stk duals dented and flattened. 280 RWHP 315 RWTQ Headers and 2.5 ex should have me in the 12 sec 20 mpg club. The 3:55s and M21 make it way tall off the line. I love the BB mid range that squirts me through traffic. The catalog lists this as the most cam that can be run w/stk converter. A 5 sp will change my outlook I'm sure. JMHO
Rick
Old Mar 30, 2006 | 09:44 PM
bobs77vet's Avatar
bobs77vet
can't wait to see it....
