Rounded head bolt
Old Aug 27, 2001 | 01:37 PM
ZD75blue's Avatar
ZD75blue
Default Rounded head bolt
Hi all
This is one of those dumb questions that I ask every so often
How do you get a rounded of exhaust manifold bolt out? I have tried all that I have thought of Vise grips, mm sized bolts, pipe wrench (was bronze so it didnt do much). I am out of ideas and the bolt is still in the manifold
Are there any tricks do removing these?
ZD
Old Aug 27, 2001 | 01:43 PM
john's '81 mouse's Avatar
john's '81 mouse
Default Re: Rounded head bolt (ZD75blue)
Try to borrow someone's "Metwrench", these are supposed to work even on rounded off bolts. (These sockets work off of the SIDES of the bolt head, not the corners, which do round off.) You might check at Sears, believe they might sell these kind of sockets, but not sure. Suppose as a very last resort you could try to cut the head of the bolt off with an air chissel, or something like that.
Old Aug 27, 2001 | 02:23 PM
lars's Avatar
lars
If all else fails, remove all the other bolts, and then grind the head off of the damaged one. You can thus get the manifold off. Once the tension is gone from the bolt and the manifold is removed, you can then get the remaining bolt stud out of the head fairly easily with vise grips or a stud remover provided it is not corroded into the head.
Old Aug 27, 2001 | 02:45 PM
ZD75blue's Avatar
ZD75blue
do any of you guys know if craftsman makes 6 point box end wrenches (i beat this bolt up with the 12 :cry )
I will try the metwrench idea, but what exactly does it do?
Old Aug 27, 2001 | 02:48 PM
vettetester's Avatar
vettetester
goto advance or autozone their 6 points are good enough, if all else fails(like it did for me) use a dremel and grind the bolt head off
Old Aug 27, 2001 | 03:03 PM
Tym2Think's Avatar
Tym2Think
Yes, Craftsman does make Six point (That's what I use) Don't know if they sell them seperate (I got in a kit) , I assume they do.
Old Aug 27, 2001 | 07:11 PM
ZD75blue's Avatar
ZD75blue
Default Re: Rounded head bolt (Tym2Think)
hmm wonder how much a set of 12 will go for on ebay :D have to call em special edition or something :jester
Thanks guys but would like to know how to use a dremel you can tell I'm kinda green at this :yesnod:
ZD
Old Aug 27, 2001 | 08:04 PM
jerryp58's Avatar
jerryp58
I seem to recall previous posts that suggested using a dremel to cut a screw driver slot in the head and try to get it out with a big screwdriver. If that tears up the head you could always still go with the "remove the (whole) head" approach.
I know I'm stating the obvious, but you have soaked that puppy with penetrating fluid, right?
[Modified by jerryp58, 7:05 PM 8/27/2001]
Old Aug 27, 2001 | 08:11 PM
PatsLs1vette's Avatar
PatsLs1vette
Default Re: Rounded head bolt (jerryp58)
i have a set of snapon sockets that work great for rounded heads not cheap though 225 for the set but worth every penny i paid...
Old Aug 27, 2001 | 08:18 PM
ZD75blue's Avatar
ZD75blue
yeah I used penetrating oil on it
just got the wrench sidewas and messed the tips up :cry
Thanks for the help guys I will look into the metwrench and see what snap on carries
ZD
To Rounded head bolt
