Tunable carb
Old Jun 19, 2006 | 11:38 AM
sly vette's Avatar
sly vette
Default Tunable carb
I got a Q-Jet carb from a friend and I was wondering if it is considered a tunable carb for street use??? #17057287 Also if someone could tell me what was this carbs original application,it would be greatly appreciated..
Later,
Sly
Old Jun 19, 2006 | 11:44 AM
markdtn's Avatar
markdtn
Appears to be a 77-80 Mercruiser 305 or 350 marine carb. Probably a good base to build from, marine carbs don't have much in the way of emissions provisions.
Old Jun 19, 2006 | 11:51 AM
sly vette's Avatar
sly vette
I was wondering how many variations of rods and jets it will accept?
Old Jun 19, 2006 | 12:25 PM
markdtn's Avatar
markdtn
That would be a Lars question.
Old Jun 19, 2006 | 07:46 PM
BigBlockk's Avatar
BigBlockk
There were 94 different secondary metering rods made for the 'Jet. Primary metering rods from 36 to 50 or there abouts. Primary jets from 66 to 78. There were 4 or 5 different float shapes and around 14 or 15 different secondary rod hangers. This, together with 3 or 4 different auxiliary fuel enrichment schemes, 2 different sizes (750 and 800 CFM) and the fact that the carburetor is basically infinitely adjustable, the answer to your question is, no, the Quadrajet is not very tunable so you may as well send it to me. I'll pay shipping.
The Quadrajet is the most tunable carburetor EVER installed on any mass produced automobile. I would say up wards of 25 to 30 million have been made.
BigBlockk
Later.....
Old Jun 19, 2006 | 10:31 PM
sly vette's Avatar
sly vette
So I take it your pulling my chain and I should kep it and tune it????
Old Jun 19, 2006 | 11:23 PM
BigBlockk's Avatar
BigBlockk
There are 2 schools of thought here on the boards. There are those that replace the 'Jet with a Holley and those that learn to tune the 'Jet. The Holley is simply an expensive way to pour gasoline into an engine while the Quadrajet actually meters fuel properly. Yes, I think you should tune the 'Jet.
BigBlockk
Later.....
Old Jun 19, 2006 | 11:38 PM
90ZR1's Avatar
90ZR1
I'm a quadrajet newbie. I just successfully removed and re-installed my distributor and the car fired right up! Now I plan on curving it. But first I want to change the idle speed. Soooo, (Bigblock) where is the idle speed adjustment screw on a 74 L48 Q-jet?
Old Jun 20, 2006 | 10:16 AM
lars's Avatar
lars
Driver's side at the throttle lever. Fast idle screw is on the passenger side under the choke hardware.
Lars
Old Jun 20, 2006 | 05:02 PM
Kalway's Avatar
Kalway
BigBlockk
Later.....
Hardest part of tuning later model q-jets is finding those damn primary metering rods. I'm running 47K rods with 75 jets and it runs reeeeal nice. I left the secondaries the way edelbrock sent them as.
Old Jun 20, 2006 | 06:22 PM
BigBlockk's Avatar
BigBlockk
Good point. Not all of these are still available. I know Lars has had to make his own metering rods.
BigBlockk
Later.....
Old Jun 21, 2006 | 02:42 AM
Kalway's Avatar
Kalway
BigBlockk
Later.....
Yup, he turned my 48M to the 48K spec. I just switched those out for some original 47K rods this weekend and the throttle response at cruising speeds seems to be a little gruntier. Of course I'm sure the adjusted timing curve and better fuel helped with that, too.
Old Jun 21, 2006 | 06:14 AM
comp's Avatar
comp
Old Jun 21, 2006 | 08:52 PM
sly vette's Avatar
sly vette
Well I guess I get to go to Jet school
Old Jun 21, 2006 | 09:00 PM
Kalway's Avatar
Kalway
Honestly, I think q-jets are easier to understand than Holleys and Carters. However, I've never owned a Holley or a Carter so I can't speak from experience.
To Tunable carb
