Header install
Old Jul 13, 2006 | 08:31 PM
Fstdraw's Avatar
Fstdraw
Default Header install
I'm installing a new set of ceramic coated Hooker comps on my Alum. headed 406. Whats the best gasket to use? Copper, stock fiber, or something else? Any tricks for longevity? Thanks
Old Jul 13, 2006 | 09:24 PM
b71vette's Avatar
b71vette
Earl's Square Port (1.50" x 1.50") Header Gaskets EAR-29D03BERL - used on my 383 Stroker with AFR195 Aluminum Heads, no leaks
Old Jul 13, 2006 | 09:48 PM
bobs77vet's Avatar
bobs77vet
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
make sure all you header bolts will not bottom out preventing a good seal.....
Old Jul 14, 2006 | 12:32 AM
Little Mouse's Avatar
Little Mouse
Use studs on aluminum heads.
Old Jul 14, 2006 | 12:36 AM
Bob Onit's Avatar
Bob Onit
Great advice but nobody ever listens, plus it makes it harder to install the headers.....wreck a few threads and youll see what a benifit studs are to aluminum
Old Jul 14, 2006 | 02:39 PM
Driftwood's Avatar
Driftwood
I originally was using a thin gasket and always had leaks. I switched to Earl's and the exhaust leak diappeared. It looked like the Earl's gasket had slightlly smaller port holes, so that probably helped.
Old Jul 14, 2006 | 04:32 PM
gkull's Avatar
gkull
I just did new ARP 5/16 thread hex nut universal studs for aluminum heads. The drivers side Hooker pipe went right in from below without plugs installed. The passenger side I had to remove my mini starter and they fit right up.
I have big port heads so I'm using the felpro Blue steel. Actually reusing they might be years old and on several engines.
To Header install
