time for the pros?
bumped the motor until the problem cyclinder was finishing it's exhaust stroke. Removed both intake and exhaust rocker arms from that cyclinder so that the valves could close freely. Put an air hold fitting in the spark plug hole and attempted to pressurize the cyclinder. This is where we ran into a problem. The cylinder would not hold pressure. It would bleed off the pressure before we could try and compress the spring. We would pressurize at about 100-120 psi and this would bleed down in the matter of a minute or so. We tried the same technique on a good cyclinder and this one did hold pressure but we noticed that when we went to compress that spring we could force the valve down with our lever style spring compressor. This was at about 100-120 psi. (the max my wimpy little compressor could produce) But it did not bleed pressure like the problem cylinder.
So, before I head off to the pro's, my questions are...
Are we doing this correctly? Having the both rockers off I would assume the valves could seal and pressure should hold. Does it matter what part of the engine cycle the cylinder is no before you pressurize it?
Since the cyclinder will not hold pressure I must have some internal damage either to the piston or valves or other, correct?
Just for future reference, what pressure should be able to hold the valve up while compressing the spring?
I'm probably going to take off the head on that side and see what the internals look like. Hoping for the best but thinking the worst
I do use a rubber/plastic hammer to tap the retainer to free the keepers but yes the air should hold the valve up while you push down with your spring compressor but remember to give it a hit with the plastic hammer to jar the keepers loose.
Also stuff rags anywhere where you think a keeper could fall down into and become lost.
Before you compress the spring you need to tap on the retainer, otherwise it sticks and the valve will open.
Hopefully this will hold the valve up so you can change the spring. After you're done remove the rope, reinstall the plug and see how it runs.
It's worth a shot.
BigBlockk
Later.....
