I'm just thinking back to Rich's "tuft" tests. At speed, his car (okay all our cars) is taking air IN from:
the cowl
the side vents
the grills/front/below the spoiler (obviously)
So where is all the air GETTING OUT? Other than a couple hundred CFM that's getting inhaled/combusted, I'd guess that most of it is leaving through the bottom of the engine compartment, then below the car and out the sides??
I dunno, is all this getting-more-air in just increasing the high-pressure area under the car? That can't be good for high-speed stability/aero.
This is correct. Most of the air exits under the car. The early Gran Sport C-3's solved the preasure problem by using tons of louvers. The most effective vents fot C-3's are the big '68-69 side gills, but only if you remove all the "obstructions" (vac tank, coolant tank, heater hoses, etc) like the LeMans cars.
On your scoop, you've limited yourself to a given opening area, that can only increase preassure in that small area at speed. I would recommend losing the bottom and moving the side "fences" outboard. You'r trying to keep the high pressure air from "spilling" out the sides, and your deep spoiler will force air up and in, increasing pressure a bunch if the 'fences' are correct for your car.
At low speeds (under 15-25 MPH) none of this matters, it's all fan and radiator. With A/C, it's especially important that you vent effectively, but either way, get ready for a hot floor!
Maybe I should take those 2 10 inch electric fans I was using for the radiator and move them to the two openings behind the front wheels to help remove hot air from the engine compartment?????
ESU
Actually,those fans are better off moving air thru the rad...the air will exhaust from the side vents...
the cowl
the side vents
The front spoiler restricts air going under vette and creates downforce..when I did the yarn tuft test,I was not able to get photos of air at side vents except at idle,and air was coming out....
Alas on the 78 and all the rubber nose cars I imagine... there is a big fat steel plate that is hidden behind the eurathane that is our legal 5 mph bumper...it is bracketed and welded to the frame.. so no opening that up
I think this continued at speed...
Didn't you say that after you stopped, all the yarn had been sucked in?
(at least that's what I remember reading, I could be mistaken).
On the other topic, I bet Norval doesn't have that big heavy metal plate behind his license plate anymore. I also thought about taking that out/off somehow and adding a pre-72 style center grill/intake. Nothing the ol' plasma-cutter couldn't remedy.
Hans
Yes..agree making scoop wider will bring more air in..to a point...I'm not sure how much more I should go...think the ram air effect would be compromised at some point...just not sure..
Good point also about the "hot floor"....I did not think to take Raytek readings today....but I will tomorrow..also, I'm ordering shields for the exterior footwells like on my 69.which has much lower temps than the 78 at interior footwells..
Not at the side vents...but at speed,I was not able to observe them....so all I got is a pic after I stopped...so,guess we could assume it is an open question...?? But..I may be able to talk my wife into photographing that tomorrow...easy to do on either the 78 or the 69...
You may be thinking of the yarn I had just behind the rear window.. ???
They were being "sucked in" towards window at 40 mph...
Here is one pic from JPhil's yarn test at 65 mph....note yarn blowing out of side vent..interesting is turbulent air in front of vent..at least it appears that way....the 78 vettes have a flair just at front of side vent....maybe that causes the turbulance..???
And one stopped to illustrate his placement of yarn..
We dubbed his vette "Stringray"......
Rich
