Vast Engine Problems
Old Aug 27, 2006 | 05:04 PM
  #121
JustinD's Avatar
JustinD
He was a great guy. We got my car working great. I can't thank him enough.
Old Aug 27, 2006 | 05:28 PM
  #122
sperkins's Avatar
sperkins
Dude, you can't leave us hanging like that.
Details please..
Old Aug 27, 2006 | 05:30 PM
  #123
five-o's Avatar
five-o
"I should have just got a old stang with a 289 HO."
Now you're just being delusional.
Sounds good to me. The 302 is always a good alternative too. Oops, vette forum, right...
Old Aug 27, 2006 | 05:33 PM
  #124
Little Mouse's Avatar
Little Mouse
you did not have to pull the big cam LT1s had dur. fiqures like
yours 9.00 comp in 71, they did not burp and stumble around.
Torque converter please. May the horse power be with you.
Old Aug 27, 2006 | 05:36 PM
  #125
JustinD's Avatar
JustinD
I figure it has about 9.4:1 right now. The problem was a mixture of many things, a couple of the rockers were out of adjustment and it was not on the idle circuit. The timing was close but needed a little adjustment. Along with the carb.
Old Aug 27, 2006 | 05:38 PM
  #126
Little Mouse
rumpity, rumpity , rumpity.
Old Aug 27, 2006 | 05:47 PM
  #127
sperkins's Avatar
sperkins
That's great news. Hope your Mom has a new outook on the Almighty Corvette Forum.
Now go burn some rubber!
Old Aug 27, 2006 | 06:33 PM
  #128
JustinD's Avatar
JustinD
Yes, in gear stopped it is very rumpity.
Yes, I think she does. As for the burning rubber I'm not so sure about that. A tubor 350 with the stock converter and 3.08's in the rear. Makes for a dog off the line with the aggresive cam. I was in a dusting of sand just a bit ago and nailed it. I layed down a patch for 25 feet at least. No brake stand either.
Old Aug 27, 2006 | 06:43 PM
  #129
Little Mouse
justin my 78 454 3/4 ton pickup, turbo 400, 373 posi, I would load it up against the brake it would not burn rubber 5 feet, must have had a
no stall converter. You would think a pickup with probably 60
percent of the weight on the front tires would burn some rubber.
Old Aug 27, 2006 | 06:49 PM
  #130
Bob Onit's Avatar
Bob Onit
If his Mom thought meeting people on the net was unsafe wait till Justin takes her for a WOT ride in this 400+HP monster
I can see it now
Ill take the keys until your 30
Old Aug 27, 2006 | 06:59 PM
  #131
JustinD's Avatar
JustinD
I opened her up a bit today gets up to 60 pretty quick for the rear end I have in it.
Old Aug 27, 2006 | 07:12 PM
  #132
mandm1200's Avatar
mandm1200
This all started back in June. I believe you wanted to take it to school. Hopefully you were a junior back then so you could now start off your senior year cruising in a mean, bad azz Vette. I know Roger offered as much help as he could in order for you to be able to take it to school.
Old Aug 27, 2006 | 07:16 PM
  #133
Bob Onit's Avatar
Bob Onit
So Justin, would you say the car is running great, perfect or good..which is it?
Im glad you will be able to use it next week to show the ricers what a real car is
Please be careful Justin......... Im serious
All that work and frustration probably wont look to good wrapped around a tree.
Not to mention your brains as well
Old Aug 27, 2006 | 07:17 PM
  #134
JustinD's Avatar
JustinD
Ya, I don't really want it wrapped around a tree. BTW the car runs great. I need different rear end gears for it to be perfect. Not enough low end grunt.
Old Aug 27, 2006 | 07:22 PM
  #135
Little Mouse
Damn was it June I was only guessing July, Augest. Justin may
be the only 18 yr old with gray hair in Minnesota, Or did he go bald
from pulling it out. I tried my damndest to get him to use the FORD
tune up tool.
Old Aug 27, 2006 | 08:20 PM
  #136
JustinD's Avatar
JustinD
Not bald, but I might have a couple grey hairs.
Old Aug 27, 2006 | 08:21 PM
  #137
406shark's Avatar
406shark
Justin...
Glad to hear you are happy with the results. Once you get some gears and a decent stall in there it will scream.
The problem with the car...
There were a couple of the rockers that needed adjustment. The carb was not on the idle circut. The timing was jumping all over the place. One minute it would be at 8 BTDC, then it would be 12 BTDC. It had a total advance of only 25 BTDC. All timing was without the vac. advance hooked up.
Pulled the cap and inspected the weights. They were aftermarket ones, and as Lars says it's best to use the factory weights. The weights were very stiff and wouldn't allow full advance, not to mention that they would not return to the closed position. We replaced the weights with the factory ones (which worked smooth), then with the springs out we checked how much advance the dist. would allow with the installed bushings. We then played around with the springs to find some that would work. The advance now comes in at about 1400-1500 rpm, with full advance all in at about 2700 rpm. Total is set at 35 degrees without vac. advance. I adjusted the idle mixture screws to allow max vac. and idle speed. Then I adjusted the curb idle speed for about 750 rpm in drive.
No hesitation, no stumble, no drama.
It does need a stall and steeper gears to help it out of the hole, but it is plenty driveable as is. All in all a pretty good outcome.
Justin, remember my number when and if you need help with your project.
Later,
Jeff
To Vast Engine Problems
Old Aug 27, 2006 | 08:27 PM
  #138
sperkins's Avatar
sperkins
***** Jeff is the man *****
Old Aug 27, 2006 | 08:32 PM
  #139
Little Mouse
Originally Posted by 406shark
Justin...
Later,
Jeff
Great work sounds like most of his problem was in the dist.
Old Aug 27, 2006 | 08:40 PM
  #140
406shark's Avatar
406shark
Most "carb" problems are. The problem with carbs is that they mounted them up on top where everyone can play with them. I always look first at the dist. and timing events.
Justin has tackled alot for someone his age. Hell, it's alot for most people. I'm impressed with his ambition and drive. I figure if he puts himself into his career half as much as his Vette he is going to be a very successfull person.
Later,
Jeff
