Pcv
Old Oct 1, 2006 | 03:47 PM
Silver00V6Camaro's Avatar
Silver00V6Camaro
Default Pcv
Ok got my yearone roller motor in yesterday and i am in the processe of running the vaccum lines and everything else. My question is can i use breathers instead of a pcv valve. and has anyone ever had a problem of not getting the breathers to fit in the centerbolt valve covers I have tried 4 different push in breathers and can get a one to fit.
Old Oct 1, 2006 | 04:40 PM
zwede's Avatar
zwede
You can use breathers instead of a proper PCV system but you have to change the oil more often and even then you will have increased wear. You will also probably spit some oil out the breather at WOT, especially until the engine is fully broken in.
Why do you not want to run a PCV?
