Timing gears...
Old Nov 29, 2006 | 07:06 PM
vettemanosteel's Avatar
vettemanosteel
Cruising
Default Timing gears...
Jus wonderin why most timing gears cannot be used with hydraulic roller cams, any info would be appreciated, tryin to put together a 350 for my 77 and I got a good deal on a Pete Jackson gear drive.
Old Nov 29, 2006 | 10:50 PM
zwede's Avatar
zwede
Huh? Why not? I'm using a common comps double roller chain with my hydraulic roller cam. Just have to put a cam button on it to prevent the cam from walking.
Old Nov 29, 2006 | 11:26 PM
mkflanagan's Avatar
mkflanagan
He as about timing GEARS not chains...big difference.
Old Nov 29, 2006 | 11:33 PM
zwede's Avatar
zwede
Ah, ok.
Old Nov 30, 2006 | 11:04 AM
TimAT's Avatar
TimAT
Default gear drive
If the car has a knock sensor, the gear drive will make enough sound to cause the sensor to retard the spark. The gear drives I've looked at all have a disclaimer saying they will not work on knock sensor equipped cars. I've seen fuel pumps have a ticking sound and cause the same effect.
Old Nov 30, 2006 | 12:58 PM
69monzaredbigblock's Avatar
69monzaredbigblock
If you don't have a knock sensor can you use a gear drive on a hydraulic roller cam?
Old Nov 30, 2006 | 01:28 PM
mandm1200's Avatar
mandm1200
I don't know why that would be. They are used with mechanical roller cams.
Old Nov 30, 2006 | 01:41 PM
vettemanosteel
Cruising
thnx for the info, I was just wondering because summit says my gears can't be used with a hydraulic roller cam but I couldnt see why.
Old Nov 30, 2006 | 02:51 PM
Little Mouse's Avatar
Little Mouse
I think what Summit is referring to is you can't use it on the later
factory hydraulic cams it would work on a retro fit hydraulic cam.
the front of later cams is different from early cams.
Old Nov 30, 2006 | 07:24 PM
vettemanosteel
Cruising
Yea thats what I was thought the reason could be, couldnt think of anything else it would affect besides the knock sensor. thnx for the help
To Timing gears...
