Mini-starter
Old Dec 28, 2006 | 02:26 PM
TERRY CLARK's Avatar
TERRY CLARK
Default Mini-starter
Anybody using a high torque mini-starter on their small block?.......Any recommendations ! Good or bad.
Old Dec 28, 2006 | 02:33 PM
mrvette's Avatar
mrvette
Yes, I had troubles with my old boat anchor, and finally switched it out for a cheapy AZ rebuilt....I have a staggered bolt mounting so the starter is a bit harder to find than an inline mounting bolt pattern....dunno even why the change....168 tooth wheel...
Old Dec 28, 2006 | 02:43 PM
gyopp's Avatar
gyopp
I'm using the Summit SUM-820323. It works and fits great.
Old Dec 28, 2006 | 02:44 PM
TERRY CLARK
I'm a little confused about the price on mini-starters, they range from $60 to $300 or more. Are you paying for the name or difference in quality.
Old Dec 28, 2006 | 03:14 PM
BLACK SHARK's Avatar
BLACK SHARK
From: In the shop most of the time,,, And it BEER TIME somewhere
Stay away from cheap cheap cheap. You get what you pay for.
Old Dec 28, 2006 | 03:44 PM
dmaaero's Avatar
dmaaero
i don't know about the starters but i've heard the mini altinators work great not to mention the cool factor
Old Dec 28, 2006 | 03:47 PM
norvalwilhelm's Avatar
norvalwilhelm
I just picked up a new one an hour ago. It was recommended that I went with the TCI They have never had a problem/complaint with them. It was $259 CDN
My last mini starter was a no name and it lasted a few years but was feeling tired so I bought a new one while I was at it.
I did have to rotate it to clear the block. They are adjustable as to solenoid location but only the center location fit my Merlin block.
Old Dec 28, 2006 | 03:52 PM
Durango_Boy's Avatar
Durango_Boy
Norval...you have a high compression motor right? Could that have had anything to do with the short life of your last mini starter?
Old Dec 28, 2006 | 04:07 PM
DZRick's Avatar
DZRick
I bought one off E-bay and have been using it for four years now with no problems.
I think it was around $130 but I don't remember the sellers name.
Old Dec 28, 2006 | 04:25 PM
Bullshark's Avatar
Bullshark
CI 5 & 8 Veteran
I have a high torque mini on the 69 427 high compression vert. Probably running just shy of 12:1. NO problems and its been 3 years. It does have FI on it so it starts with very little cranking.
Bullshark
Old Dec 28, 2006 | 04:50 PM
mrvette's Avatar
mrvette
Norval needs one off a diesel BUS.......
Old Dec 28, 2006 | 04:54 PM
MN80Vette's Avatar
MN80Vette
I had a GM Performance Parts high-torque mini #12361146 on my 350 HO crate for 5 years. It works great and I haven't had to touch it since I installed it.
GMPP's description:
This gear reduction starter is designed for 1958-1996 V-8 and all 90? V-6 engines. It has a compact design that provides increased clearance, weighs only 10. 5 pounds and has a gear reduction of 3. 75:1. It is equipped with a dual bolt pattern for 12. 75" (153-tooth) and 14" (168-tooth) flywheels, and the housing can be rotated to clear exhaust systems. Kit includes starter, mounting bolts, shims, gaskets, and electrical connectors.
Old Dec 28, 2006 | 05:13 PM
jhuff's Avatar
jhuff
I am looking for one of these as well. I just got a Hitachi for my 75 w/ manual transmission, but it doesnt fit. idk why but supposedly it has to do something with the fact that its a manual. the shop said something about its hard to find one for a manual despite the fact that it says it works for a manual on the box.....
Old Dec 28, 2006 | 06:21 PM
redvetracr's Avatar
redvetracr
one difference is probably the HP of the starter motor itself....
...redvetracr
Old Dec 28, 2006 | 07:50 PM
Durango_Boy
Does anyone know of any brands to watch out for?
Old Dec 28, 2006 | 07:57 PM
Ratsirt's Avatar
Ratsirt
I was having all kinds of starting problems with my small block until I installed a powermaster 180. It seems to have cured the problems.
Old Dec 28, 2006 | 10:41 PM
75 Hot One's Avatar
75 Hot One
GMPP #9000852 fits 168 tooth flywheel both small & big blocks. $229 at Scoggin Dickey- very good starter.
To Mini-starter
Old Dec 28, 2006 | 11:25 PM
Durango_Boy
Wow that's a lot of coin. I'd be comfortable paying half that considering how little I get to drive the car, and how it'll be fuel injected and will crank a lot less.
Old Dec 28, 2006 | 11:30 PM
second76's Avatar
second76
I ordered one from Amazon for $83 after $20 discount but it has been back-ordered for a while.
Quality-Built 6449MSN Supreme Domestic Starter - New
http://www.quality-built.com
It is a remake of the starters gm used in trucks from 1996 to 2002. From comparing pictures, it looks like the gmpp bb502 starter that others are using.
It is the last component (I hope) that I need to install the TKO-600 auto to manual kit from Keisler.
Old Dec 28, 2006 | 11:32 PM
Durango_Boy
That's sure a better price.
