Mini-starter
Old Jan 9, 2007 | 01:54 PM
  #61
11Jake's Avatar
11Jake
Originally Posted by DZRick
I bought one off E-bay and have been using it for four years now with no problems.
I think it was around $130 but I don't remember the sellers name.
I also bought one from ebay for $130, it was from member HotRodder. It maybe the same guy you bought yours from. I just started to use it had it works great!
Old Jan 9, 2007 | 02:01 PM
  #62
Durango_Boy's Avatar
Durango_Boy
What brand is it?
Old Jan 9, 2007 | 02:11 PM
  #63
11Jake's Avatar
11Jake
Originally Posted by Durango_boy
The battery was new when the problem started getting annoying. Not only that, the car starts GREAT when it's cold. Maybe a full revolution, and it's firing. After I go for a drive...and shut it down and get back in...it really strains to turn over. If it sits for another 30 minutes to an hour...it starts great again. I've had the carb rebuilt and then changed in the midst of all that and that didn't solve anything. Not a fuel problem. I went through a few different alternator applications trying to keep up with all the electric components I was adding, and I never solved it that way either. It seemed, when I had this problem in an old Dodge truck, that when I switched from a new can starter to a new mini starter...the problem stopped. I just don't get it if it's not the starter getting hot and not wanting to turn the motor.
I had the same problem in a chevy truck years ago. I installed full length headers in the truck beacause I beefed the motor up some and the headers were really close to the starter. At the time I couldn't figure out why it was hard to start if the motor was hot and it started fine before the mods. A buddy of mine said that the starter was getting excess heat form the headers and that I needed to get a heat sheild. I got one from summit for $14 and it solved the problem.
You can try a heat sheild. Could be just a $14 fix.
Old Jan 9, 2007 | 02:13 PM
  #64
Durango_Boy
That I would do for sure, but I'm replacing the motor and the new starter is a mini...so I will hopefully not have any of these issues any more.
Old Jan 9, 2007 | 02:14 PM
  #65
11Jake's Avatar
11Jake
What brand is it?
I don't remember, when I get home from work I will check. I have a fairly high compression motor and it turns it over with ease.
Old Jan 10, 2007 | 08:41 AM
  #66
11Jake's Avatar
11Jake
What brand is it?
I looked last night and it didn't have a brand name on it.
Old Jan 10, 2007 | 08:48 AM
  #67
Jims79's Avatar
Jims79
DZ what is the brand name of the starter?
Old Jan 10, 2007 | 10:06 AM
  #68
Durango_Boy
That's a little scary...not knowing who made it or if it was even born in this country. I have no doubt it works great turning your high compression motor. I just wonder how long it'll last...as that's the downfall for cheap starters.
Old Jan 10, 2007 | 10:55 AM
  #69
11Jake's Avatar
11Jake
Thats true, it was only $130 so if it dies early so what. If it does die I will cough up the cash for a good one. I would imagine it is probaly the same quality as the catalog brand names like Summit or Jegs.
Old Jan 11, 2007 | 05:40 PM
  #70
Juice110's Avatar
Juice110
Anyone recommend a particular flywheel on an automatic with GM mini-starter?
Old Jan 15, 2007 | 11:05 AM
  #71
Durango_Boy
I say stick with GM stock wheels so long as the tooth count matches.
