Mini-starter
Old Dec 29, 2006 | 01:09 AM
jhuff's Avatar
jhuff
Originally Posted by second76
I ordered one from Amazon for $83 after $20 discount but it has been back-ordered for a while.
Quality-Built 6449MSN Supreme Domestic Starter - New
http://www.quality-built.com
It is a remake of the starters gm used in trucks from 1996 to 2002. From comparing pictures, it looks like the gmpp bb502 starter that others are using.
It is the last component (I hope) that I need to install the TKO-600 auto to manual kit from Keisler.
it doesnt say that that one works with a chevy from the c3 generation
Old Dec 29, 2006 | 07:20 AM
markdtn's Avatar
markdtn
I have one from a 90 C4. Works great. Also used stock on some Z71 pickups in early 90s.
Old Dec 29, 2006 | 08:39 AM
rj8806's Avatar
rj8806
Guys:
Just so you know, I have been following this thread and taking notes on starter part numbers that you all have listed. I understand that some of you out there with our kits were not told of the need to swap the starter(auto to manual swaps). I will pass the part numbers along to the sales staff so they can inform potential future customers of the need and provide them a part number as well. Thank you.
Richard
Tech Support
Keisler Engineering
Old Dec 29, 2006 | 10:24 AM
Durango_Boy's Avatar
Durango_Boy
Originally Posted by rj8806
Guys:
Richard
Tech Support
Keisler Engineering
Nice heads up move Richard. Spot on.
Old Dec 29, 2006 | 10:42 AM
gkull's Avatar
gkull
Guys:
Richard
Tech Support
Keisler Engineering
I have the Summit mini starter 153 or 168 flywheel. I've had it for 5 years now on several variations of 383's and my 427 small block. It just zings the motor with 222 ft-lbs and 4:1 gear reduction. It's made for 18:1 500 ci race motors
#SUM-820323 I think it's @ $150. I'm not sure because I had enough points that they threw it and something else in free when I was down at the Summit store
Paul L's Avatar
Paul L
This is a nice unit. It's been on my former 1979 for about six years.
Old Dec 29, 2006 | 12:51 PM
Durango_Boy
Ooh, that one's pretty. How much was it if you don't mind spilling?
Old Dec 29, 2006 | 01:45 PM
jerome1979's Avatar
jerome1979
Sorry for a so stupid question!
but what type of starter do I need for a T56 from a LT1
my 168 teeth stock starter is ok?
Old Dec 29, 2006 | 02:02 PM
rj8806's Avatar
rj8806
gkull:
Is that starter a staggered or straight bolt pattern??
Richard
Old Dec 29, 2006 | 02:06 PM
rj8806's Avatar
rj8806
Originally Posted by MN80Vette
I had a GM Performance Parts high-torque mini #12361146 on my 350 HO crate for 5 years. It works great and I haven't had to touch it since I installed it.
GMPP's description:
This gear reduction starter is designed for 1958-1996 V-8 and all 90? V-6 engines. It has a compact design that provides increased clearance, weighs only 10. 5 pounds and has a gear reduction of 3. 75:1. It is equipped with a dual bolt pattern for 12. 75" (153-tooth) and 14" (168-tooth) flywheels, and the housing can be rotated to clear exhaust systems. Kit includes starter, mounting bolts, shims, gaskets, and electrical connectors.
Any idea what they go for $$$????
Richard
Old Dec 29, 2006 | 02:17 PM
gkull's Avatar
gkull
gkull:
Is that starter a staggered or straight bolt pattern?? Richard
Racecar cranking power.
Summit's lightweight Nippondenso-type Protorque starters offer a 4.0:1 gear-reduction ratio and a whopping 1.9 HP. That's 222 ft.-lbs of racecar cranking power. If that's not enough, there are even more powerful 3.1 HP monsters, which are a pound lighter! They have a 4.44:1 reduction ratio and churn out an awesome 342 ft.-lbs. of torque. Both of these powerhouses are suitable for engines up to 502 c.i.d., and compression ratios of up to 18.0:1. GM versions are adjustable for four mounting positions; Ford types, for 18. A gold dichromate finish prevents corrosion and electrical shorts on both.
my older 168 flex setup with a 9.5 inch 3800 stall torque converter
Old Dec 29, 2006 | 03:25 PM
rj8806's Avatar
rj8806
Thanks gkull for the info. I'm passing along that part number as well to the sales guys.
I appreciate all of the info everyone.
Richard
Tech Support
Keisler Engineering
Old Dec 29, 2006 | 09:07 PM
  #33
Ironcross's Avatar
Ironcross
Default Your Best Bet Starter!
Originally Posted by 75 Hot One
GMPP #9000852 fits 168 tooth flywheel both small & big blocks. $229 at Scoggin Dickey- very good starter.
This is GM`s answer for a light weight starter. Your best bet over any aftermarket high dollar trick stuff. The Canadian cost is too high, but in the USA available at nearly any auto parts store for less than a 1/3.
Old Dec 29, 2006 | 10:29 PM
  #34
kaiserbud's Avatar
kaiserbud
Gkull - nice pics....
as I listen to this thread, I am thinking I will have to re-assess my 'mini-starter'. I just got it from an old 383 and thought I would use it. Will find out what kind it is and compare with ya'll's input.
Old Dec 29, 2006 | 10:46 PM
  #35
a1sensei's Avatar
a1sensei
After going through several rebuilts from advance auto parts (lifetime warranty, but who wants to replace the starter every 6 months!), I got a mini off ebay. I think the seller was skip white. It was dirt cheap and has given me no problems for several years now. My stock starter was staggered bolt, the mini is straight bolt but it fit fine. The only problem is that it sounds like a Dodge (I swear!). God bless, Sensei
Old Dec 29, 2006 | 11:46 PM
  #36
second76's Avatar
second76
I was able to cross reference 6449MSN starter from Amazon on the Quality-Built Online Catalog by going to Cross Reference and entering 10465167. On Gilbert Chevrolet Starters page they state the 10465167 is a remanufactured 9000852.
It may be a stretch but I am willing to risk the cost of return shipping.
Old Dec 30, 2006 | 01:14 PM
  #37
gkull's Avatar
gkull
gkull:
Yes, you have the two verticle block holes for using 153 or 168 tooth. The 4 horizontal holes are to rotate the starter for block or more header clearance
It is harder to take a picture now because of big blow proof bell housing and headers
ample header to starter clearance - mine is rotated with the four hole against the block just how I pulled it out of the box. You can even see the block saver plate between the starter and red bell H.
To Mini-starter
Old Dec 30, 2006 | 02:26 PM
  #38
l88rocket's Avatar
l88rocket
You can use a C-4 vette starter they factory installed mini starters.some call them LT4 starters.
Old Dec 30, 2006 | 03:06 PM
  #39
Durango_Boy
Those will work on a Gen1 block? Man I should have pulled the starter off the '94 LT1 I sold.
Old Dec 30, 2006 | 03:36 PM
  #40
l88rocket's Avatar
l88rocket
Yeah a gen1 and a LT1 block are the same except front cover area
