Electric Choke
Old Mar 5, 2007 | 06:24 PM
coinwasher's Avatar
coinwasher
Default Electric Choke
Where do you pick up the power for an electric choke on a car not equiped with one? Any suggestions would be appreciated.
Old Mar 5, 2007 | 06:28 PM
JoeRags's Avatar
JoeRags
You need a switched lead. Get out your voltage tester and start testing. You want a hot lead that switches on with the ignition.
Old Mar 5, 2007 | 06:44 PM
SIXFOOTER's Avatar
SIXFOOTER
Have heard in here that the Yellow wire at the wiper motor was the place to go
Old Mar 5, 2007 | 06:46 PM
Durango_Boy's Avatar
Durango_Boy
I used an open ignition terminal on the fuse block, a relay, a power wire from the alternator, and created an IGN switched 12V fuse block. I ran the electric choke wire form it, the stereo, and I have four extra places for any other wiring needs that require an IGN source.
Old Mar 5, 2007 | 07:13 PM
lars's Avatar
lars
In the engine compartment, come off the wiper motor.
If you want to go through the firewall, come off any spare "IGN" (preferred) or "ACC" terminal on the fuseblock.
Whatever you do, don't use the hot wire feeding the ignition coil circuit.
Old Mar 5, 2007 | 11:09 PM
77BuffaloVet's Avatar
77BuffaloVet
I connected mine to the wiper motor...works fine...
Old Mar 6, 2007 | 09:25 AM
Disco_Mike's Avatar
Disco_Mike
Thats what I did.
Old Mar 6, 2007 | 09:55 AM
Binnie77's Avatar
Binnie77
Hooking into the wire going to the heater motor works as well.
To Electric Choke
