Having second thoughts about Weber Carbs
Old Mar 9, 2007 | 04:12 PM
  #61
Big2Bird's Avatar
Big2Bird
Originally Posted by Twin_Turbo
I chopped up a POS 82, I don't mind chopping stuff up but not on hard to find nostalgia parts and cars. A guy I know has a 69 Mustang 428CJ w/ the original CJ scooped hood, he wants a shaker and wanted me to help him and cut up the hood. I told him I wouldn't do it..period
THAT, I understand. I own a Model T, and racing stuff for them is WAY up there in price. Ever hear of Ed Winfield?
Old Mar 9, 2007 | 04:42 PM
  #62
Twin_Turbo's Avatar
Twin_Turbo
No but I saw boyd coddington ruin a pristinge model t and turn it into an abomination...what a shame. They ruined an old model a??? in the same episode.
Old Mar 9, 2007 | 04:57 PM
  #63
Big2Bird's Avatar
Big2Bird
I will dig up some stuff for you. The tie-in with this thread is, it is said the Weber is an updated Winfield.
Ed was a cam grinder and Carb Manufacturer, Glendale, Ca, that was WAY out in design from the others.
I will PM you some stuff sometime so you can be the judge.
He died a few years ago in Las Vegas, about age 76.
Old Mar 9, 2007 | 08:43 PM
  #64
DJ Dep's Avatar
DJ Dep
St. Jude Donor '05-'07
[QUOTE=Big2Bird;1559298071]Close. All 5 still exist. Chevy killed it when they found out he wanted to produce 200 cars.
Actually, I saw a few of the ORIGINAL ones a few times at the Chevy Vettefest in Chicago. To me, they were the highlight of the show. It still amazes me that the engine and trans are so CLOSE to where the driver sits. A fat tub of lard like me could never hope to get into the hardtops . They do make fiberglass kit cars of the Cheetah. I also have a DVD video of a test drive that guy on TV with the turned up moustache takes in an real one. It is AWESOME!!!
TT: I gota agree with you. If I ever got the scratch together to go Hilborn, it would be the racing/mechanical version. The electrical street version one is more "show" than "GO".
And Chevy also killed the Cheetah because they knew it would be direct competition for the Vette. Actually, it would have been FASTER
Dep
Old Mar 9, 2007 | 11:23 PM
  #65
birdsmith's Avatar
birdsmith
Originally Posted by Little Mouse
If duntov said this he was doing some wild dreaming if he thought
he could run with the mid engine GT 40. The grand sports aero
numbers were about as bad as roadster cobra and not even as
good as the daytona cobra. The 40 inch high ford GT had great
aero. when ferrari got trounced by the GT 40 with the 7.0 liter
427 nascar engine he got the rules changed to 5.0 liter, ford GTs
with gulf oil then kicked ferraris crooked *** with the 289 for two
more yrs.
Actually, it wasn't Enzo that got those rules changed. In 1968, using unlimited-displacement prototypes such as the GT40 MkII and the Chaparral 2F as an excuse, the French sanctioning body (FIA) had the displacement limit for prototypes lowered to 3 liters which would coincidentally allow Matra's new 3-liter Formula 1 V12 to be used in sports car racing as well. The unintended effect of this was that Porsche stepped in with their 3-liter 908's and won the manufacturer's title, while John Wyer's Gulf Oil-sponsored, well-sorted Weslake-headed Mk I GT40's continued Ford's win streak at LeMans for two more years. In spite of all the French gerrymandering, Matra still couldn't win at LeMans until 1974 when all the big factory teams pulled out. If Chevrolet/GM had given Jim Hall anything like the kind of financial backing that Ford was throwing at their LeMans effort, the Chaparrals might have had a real shot at winning there, but thinking that a Corvette in any form could compete for an overall win is a pipe dream.
Old Mar 10, 2007 | 02:42 AM
  #66
cardo0's Avatar
cardo0
From: Las Vegas - Just stop perpetuating myths please.
Default Big misconception.
synching them is easy, all you need is this:
They aren't any more difficult to tune than other carbs, in fact they may very well be easier..if you know what you're doing and have the proper tools. Some things are very important like setting the float levels.
U can sync the Weber idle circuits with sync gauges but they don't tune anything on the main circuits. U don't balance vacuum at WOT. To set the main circuits u gonna need to swap carb throut venturies and jets till u gett'm mixture tuned and that A/F analyzer will be needed for that. And now u tell me if anyone is gonn'a use anything but the same size venturi in each of the carb throuts? Jets maybe. But anyone is welcome to prove me wrong as long as they can explain how it works. Webers have interchangable venturis and of course jets so they can be modified to work in many different applications/eng displacements/rpm ranges/cfm requirements. I've been told the Webbers have changeble air bleeds in the main circuits too but i'm still not a believer of that either.
So get that A/F analyzer setup. My idea is to run 2 or more sensors through a switch so u can monitor as many pipes as u want with only one analyzer - sensors are cheaper than analyzers.
Good luck JKL and what have u got to loose now? Plenty'a power to gain with a smoother idle and man noth'n look'n badder than Webers sitt'n on top.
cardo0
Old Mar 10, 2007 | 05:36 AM
  #67
noonie's Avatar
noonie
cardo0
Sounds like you're right on.
They do have replaceable air jets. Larger air jet will lean out engine at high rpm etc.
Hopefully the setup he bought is close enough so as not to have to change venturies ($15.00@).
Once you get the initial setup with the a/f meters done (might seem endless), then the maintenance tuneups are pretty simple involving only syncing etc.
Truly a carb lover's setup only, but orgasmic when done right.
Old Mar 10, 2007 | 11:42 AM
  #68
Twin_Turbo's Avatar
Twin_Turbo
cardo0
Who said anything about wot tuning? he asked about synching them and that's the idle synch. That's where you start after setting the float levels, a base line jetting and the same chokes in all of them. when using side drafts you also have to make sure they are all at the same angle (that's why those rubber o ring type gasets suck as they allow movement)
Yes, the chokes can be changed, on the dellortos also. I have several sizes of chokes. The jets, air corrector and emulsion tubes are all changeable. so yes the webers have an air corrector. The air corrector and emulsion tube are available in many sizes (the dellortos have an even larger range w/ increments closer to each other)
I have no idea what AF analyzer you're talking about but the thing in the pic is a 4 gauge manometer. There are many special tools required, i have special measuring cup screw on adapters for my dellortos that I can check accelerator pump shot cc's with.
Old Mar 10, 2007 | 12:10 PM
  #69
Big2Bird's Avatar
Big2Bird
Piece of cake. $1900 + round trip air fare to the Netherlands.
Old Mar 10, 2007 | 12:45 PM
  #70
DJ Dep's Avatar
DJ Dep
Then we can find out FOR SURE if TT has a goatee or not
Old Mar 10, 2007 | 12:53 PM
  #71
panic's Avatar
panic
how come american performance engine builders do not give a weber carb option?..well, at least i didnt see any when shopping for my 406ci...i dont think it's because its relevant cost, if you're going to spend around 10.000+ usd on an race engine, a thousand more on top of the cake won't be that great difference...
Old Mar 10, 2007 | 01:56 PM
  #72
Twin_Turbo's Avatar
Twin_Turbo
A Goatee?? HELL NO!!!
Old Mar 10, 2007 | 02:54 PM
  #73
DJ Dep's Avatar
DJ Dep
I suspect part of the reason is the KISS principle. While Webers may look "cool and impressive", just like the tri-power setups on the old 427s, there are probably 4 barrel or 2-4 barrel setups that are way more efficient and easier to tune than Webers. Think about it...how many Webers do you see at the strrip? Almost NONE. NASCAR doesn't allow it. Fuel injection is much more efficient for racers that can use it. So Webers are more an "oddball" than anything else.
TT: Unconfirmed reports from somewhat relaible sources (Turtlevette) insist that there is some follicle growth at strategic locations on your top lip and chin.
Dep
Old Mar 10, 2007 | 03:37 PM
  #74
panic's Avatar
panic
i think it might also be because webber carbed engines would not be supported by a wide and well trained service (in usa)...
Old Mar 10, 2007 | 04:43 PM
  #75
DJ Dep's Avatar
DJ Dep
i think it might also be because a webber carbed engines would not be supported by a wide and well trained service (in usa)...
Very true.
Old Mar 10, 2007 | 05:05 PM
  #76
Twin_Turbo's Avatar
Twin_Turbo
Dep
Must have been a pic taken on a day I didn't stand close enough to the razor
Old Mar 10, 2007 | 08:40 PM
  #77
DJ Dep's Avatar
DJ Dep
ROFL!!!! Maynard G. Krebs comes to mind
Dep
To Having second thoughts about Weber Carbs
Old Mar 11, 2007 | 05:06 AM
  #78
Twin_Turbo's Avatar
Twin_Turbo
must have been this pic..that's not a goatee.
Old Mar 11, 2007 | 01:05 PM
  #79
DJ Dep's Avatar
DJ Dep
Holy moley!!! Is that REALLY you???????
Now I AM intimidated!!!!!
Dep
Old Mar 11, 2007 | 01:13 PM
  #80
Twin_Turbo's Avatar
Twin_Turbo
yes, that's me...and I DO fit in the car now that I lowered the floor
