o i dropped the new built 327 in my 65 vette the other day. finally got it all hooked up this AM. Take it out for a spin and duh. large vibration. it gets more severe with revs. hardly feel it in neutral, pretty strong under load and acceleration very strong when engine braking. it increases in frequency with RPM s but not so often as crank rotation. I didn't remove the transmission during the engine swap. tomorrow I will raise the car on jacks and get under it with the motor running try to see whats going on. any ideas.
Check the stuff D_boy suggested. If no vibrations when revving engine in the driveway, take to the road and get your vibrations going. Put the car in neutral, take foot off the gas, and coast at speed. Still got vibrations? If so, it's likely a U-joint...or if you changed driveshafts for some reason, the d-shaft was not balanced correctly.
as i sit here thinking. I am using the same flywheel / clutch I used on the previous engine. I had sent that flywheel out with the clutch and crank to be balanced for that combo. I had assumed they zero balanced it and just bolted it onto this engine. I wonder if they balanced it to the LJ cast crank in the last engine. Maybe I will rotate my clutch on the flywheel. see if that changes anything.
That is a likely suspicion. When a shop balances crank and flywheel, it's best to do flywheel separately, first...then as a set. That way, both are well balanced to begin with. If the balance was done as a set and material only taken out of the crank, that could well be your problem. Look for any balance drilling on your flywheel. If you don't see any, have it balanced and re-install. Good luck.
I re-read your last post.... If you are re-installing the crank, flywheel, clutch set from your prior engine, are the flywheel and crank still indexed as they were before? If not, see if you can match up any "wear/rub patterns" on the crank/flywheel mating surfaces to get them oriented the same as they were.
