Distributor off a tooth?
Old Mar 13, 2007 | 03:46 PM
lucky76's Avatar
lucky76
[QUOTE=mudbone64;1559348619]
Originally Posted by lars
There is no such thing as being "off one tooth." If your timing is set right, installed distributor orientation is irrelevant. If you're off a tooth, it only changes the clocking that the distributor ends up in once you time it. On some installations, you cannot get it timed because the vacuum advance will hit the back of the manifold. But if you're timed at 36 total, the installed orientation is completely irrelevant to performance - you can install the distributor in any position and still make the timing right.
I wanted to say this but didn't have the nerve!
And CHECK THOSE PLUG WIRES, TWO ARE CROSSED!
