My 73 – 350 has misfired and backfired since it has been running, after a rebuild. Set the dwell and set the timing at 36* at 3000, still have basically the same misfiring and backfiring. Does it sound like the distributor is off a tooth? Any help will be appreciated.
If you know for a fact that you are getting all your advance in at 3000 rpm, then my next questions are:
How does it idle?
Does is only backfire when you open the throttle?
Is it backfiring when the throttle is held at a steady speed?
First: If the idle is high and you can't get it to idle down, you may have a vacuum leak. Use WD-40 or something like that around the base of the carb and along the intake runners. If the engine speeds up, you have a vacuum leak.
If the backfire occurs mostly when you open the throttle, you need to check you accelerator pump on the carb. Might not be working and causing a lean condition.
If the backfire occurs at a steady speed, have the spark plug wires been off lately. There may be a crossed ignition lead.
Backfires below 1700 RPMS, misfires at higher RPMS
Depends on the RPM, usually yes.
Don’t think this is the problem.
Running rich.
New Accel 8mm wires, connected properly.
From: I'd like to propose a toast... to internal combustion and wind in the face.
You stated the engnine has not been running properly since a rebuild so I'll assume the distributor has been removed and then re-installed. Did you re-install the distributor with the number one cylinder at top-dead-center on the compression stroke? If it was then the distributor should not be your problem. Quite possibly you've got the engine "cross-wired".
Get your engine's number one cyliner at t.d.c. on the compression stroke and locate your number one plug wire on the distributor cap. Mark the wire's location on the distributor base and remove the distributor cap. If the distributor was installed properly (and if the engine timing is set properly) then the rotor button tip should be just beyond or on the other side of the mark you made on the distributor base as the rotor rotates clockwise. If the rotor tip is not where I've described then where the rotor tip is pointing is your new number one spark plug wire location. Install your number one plug wire at the new location and move the remaining spark plug wires accordingly (firing order: 1-8-4-3-6-5-7-2).
I hope have not been too elementary or too confusing. If I've given you any incorrect information I'm sure someone on the forum will correct me.
One hint to determine if you are off a tooth is to see if it runs better with the dist. cap turned all the way to one side. When we installed a friend's engine in his 80 a few years ago, we actually had it off by two teeth. It took us forever to figure it out. Eventually, we turned the cap all the way to one side, and the engine was trying to catch. We took the distributor out, moved it one tooth in that direction and tried again. This time it would only run if we had the cap turned all the way to the one direction. So, we rotated it one more tooth and it worked perfect.
Engine is at 0* and #1 TDC. Rotor was pointing at 7 o'clock - looking from the front to the back of the engine. Moved it to about 6 o'clock, haven't tried it yet...
You could be off six teeth and make it run great as long as you turn the cap to the proper timing. I time by ear. Just keep advancing until you get some detonation under acceleration with a warm engine and then back it off a little.
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
the only issue with being off a tooth is if the vacuum cannister is hitting something preventing you from getting the proper timing...almost sounds like the plug wires are in the wrong order.....i am always amazed at how well these cars run even if some plug wires are mixed up
except that TDC on the balancer could be #1 or #6 ...you need to pull the #1 spark plug and have someone click the key while you hold a finger over the hole...when the compression blows your finger off the hole thats #1
...redvetracr
You already have several answers and may have tried them. But since this is a situation from the beginning, it may be as simple as a few of the valves are too tight.
I dont think your dist. is off, if you set timeing to 36*! reason being when my dist. was off a tooth so was the timeing mark trying to use the light. chilton showes 74 and earlier with points, the #1 on the dist should point to the # 2 cylinder (what you refering to as 7 o"clock) for 74 and later with hei the #1 on the dist should point towards the #1 cylinder (what you"d call 5 o"clock) if you moved it to 6 o"clock i dont think your going to see the timeing mark with a light.
This really says it all. Won’t idle below 1700 RPMs That is a massive vacuum leak. Like the rear 3/8th under the rear bowl of a double pumper.
I would check and plug every carb ported and unported vac. connection. Plug every manifold vacuum port. Just to eliminate down stream hose leaks. If spraying flamable liquids around the base of the carb and manifold to head does not increase the idle speed, you can actually have a vacuum leak from the cam valley to the lower intake runners
There is no such thing as being "off one tooth." If your timing is set right, installed distributor orientation is irrelevant. If you're off a tooth, it only changes the clocking that the distributor ends up in once you time it. On some installations, you cannot get it timed because the vacuum advance will hit the back of the manifold. But if you're timed at 36 total, the installed orientation is completely irrelevant to performance - you can install the distributor in any position and still make the timing right.
If you cannot get it to idle below 1700 and you're getting popping and missing, you have a massive vacuum leak. If timing is right, backfiring through the carb upon throttle opening is indicative of a lean condition -associated with a vacuum leak.
[QUOTE=lars;1559348013]There is no such thing as being "off one tooth." If your timing is set right, installed distributor orientation is irrelevant. If you're off a tooth, it only changes the clocking that the distributor ends up in once you time it. On some installations, you cannot get it timed because the vacuum advance will hit the back of the manifold. But if you're timed at 36 total, the installed orientation is completely irrelevant to performance - you can install the distributor in any position and still make the timing right.
I’ll just leave it at 6 o’clock, the distributor vacuum advance was close to the firewall.
Thanks for all the advice! It’s starting to sound like a vacuum leak. The Holley 650 DP carb is from Ebay, but was completely rebuilt by me. The air horn is cut off. Everything is removed from the main body that can be removed, plugged all the holes that appeared to be potential vacuum leaks, but not all of them. I did notice when it was first started that some gas seeped out from one of the throttle base plate shafts.
Was going to replace the throttle base plate and main body with Proform parts later, but sounds like I should do it now…
I've got a 750 carb at home sitting on the shelf. It looks beautiful, but all I can figure is that it must have got water condensation while parked and then froze. The body must have internal cracks or something because it leaks gas down the throttle bores. I have also considered buying a new center body for it.
