Tapping...
Old Mar 28, 2007 | 06:04 PM
jerrylee's Avatar
jerrylee
Default Tapping...
Is there a possibility an engine tap I have is just a valve adjustment needed on my break-in or something more serious...My mech, is out of town for a week n I wish to know if by driving her I will cause any damage or not....I aslo noticed that the tap is more noticeable on start up n seems to come n go....Or is that my ear playing wishfull thinking..lol...........Thanx ....Jerrylee///
Old Mar 28, 2007 | 07:10 PM
7T1vette's Avatar
7T1vette
Hydraulic or mechanical lifters? If mechanical, pull the valve cover and see if you can locate the offending lifter (if it is a lifter)...then adjust it. If hydraulic lifters, and if they were adjusted properly, you shouldn't be having this problem.........unless you are low on oil.
Old Mar 28, 2007 | 08:54 PM
jerrylee's Avatar
jerrylee
It's hydraulic flat tappet here....n my oil is good......I did have a problem with my timing where she was pinging alot... could something have happened there....Thanx...Jerrylee///
Old Mar 28, 2007 | 09:06 PM
Eddie 70's Avatar
Eddie 70
Ci 6, 8 & 10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
Are you running an XE cam? They do have very steep ramps and seem to cause some noise.
Old Mar 29, 2007 | 06:52 AM
jerrylee's Avatar
jerrylee
Yes I am Eddie--#268....Jerrylee///
Old Mar 29, 2007 | 07:56 AM
capevettes's Avatar
capevettes
CF Community Team
Active Streak: 90 Days
2016 C2 of Year
2015 C3 of Year Finalist
If it's on the passenger side of the motor it could even be the fuel pump making the noise. Happened to me not too long ago. Sounds just like a lifter but it was the fuel pump. See if you can isolate it.
Old Mar 29, 2007 | 09:49 AM
a1sensei's Avatar
a1sensei
Jerrylee, I have an XE and the same thing happened. Yes, it could be the fuel pump rod, but more likely, the rockers may need a little more adjustment. Yes, in an ideal world, you set them up once and never touch them again, but after a short time, a couple of mine started tapping. I took off the valve covers, started it up and listened with a mechanic's stethescope (these are cheap at any parts store, everyone should have one) and tightened the offending ones about a quarter turn. I think I had to do this a couple of times, but it's been over a year and no problems since. God bless, Sensei
P.S. I think Lucas Oil Stabilizer is a good idea these days.
Old Mar 29, 2007 | 10:13 AM
77BuffaloVet's Avatar
77BuffaloVet
also check your exhaust connections, if they are leaking they will tick like lifters...
Good Luck!!!
Old Mar 29, 2007 | 08:27 PM
jerrylee's Avatar
jerrylee
Thanx 4 all your replies....Jerrylee///
To Tapping...
