Tremec TKO-600 Install problem....help!
Old Apr 11, 2007 | 01:53 PM
  #41
MYBAD79's Avatar
MYBAD79
St. Jude Donor '05
Originally Posted by Frank_833
I mated my new TKO-600 and engine last week (out of the car).
BTW, the top right bolt is in a nasty spot out of the car.
This should look familiar....
I din't have any problems with the top right bolt:
Old Apr 11, 2007 | 01:57 PM
  #42
Barry's70LT1's Avatar
Barry's70LT1
[QUOTE=Mako72;1559772589]
Originally Posted by Barry's70LT1
Barry, here's a picture from Keisler's instructions calling to cut the tool. Using a full length tool would have been too tight in my application.
Here is a picture of the alignment tool that I received from Keisler.
http://www.keislerauto.com/gm/transmissions/clutch.asp
I do not have a removable cross member, and had to do the exercise outlined by Keisler's instructions. I did use my stock bell housing.
It's a nasty way to install a transmission, (engine in the car with non removable cross member), however, I did not have to cut the tool.
It was also a loose fit in the clutch disc. I lightly snugged the pressure plate (so I could still position the disc), and moved the tool left/right and up/down and positioned the disc in the center of the movement.
My transmission went in on the first try, completely in by hand.
I guess I was lucky. Having an 18 yr old neighbor's kid helping with the lifting didn't hurt either.
I think the secret is to find the center of the slop in the alignment tool.
Barry
Old Jul 7, 2007 | 06:34 AM
  #43
Finga's Avatar
Finga
1st Gear
Default Frank
Have you sorted your problem fitting the gearbox?
