Missing fuel pressure when engine gets hot.
Old Apr 15, 2007 | 11:08 AM
karstenhorn's Avatar
karstenhorn
Default Missing fuel pressure when engine gets hot.
Hello All
Took the Vette out for a long drive today and during the cruise I got struck in some slow moving traffic. After a minute or so the car started to stumble and running very rough. When I came home it did the same again and I popped the hood. I could then see that my in-line fuel pressure gauge said a big 0 in fuel pressure and the fuel filter was almost empty. Upon revving the engine the pressure would rise to about 1 Psi and the filter would start to fill slowly. Going back to idle and the filter was running out of fuel again.
Now the funny part, when engine is cold there is perfect fuel pressure at 6 Psi, as soon as the engine heats up, fuel pressure will go down close to 0 Psi at idle and the stumbling part starts again. This is happening with the gas lid off as well and no pressure is seen in the gas tank.
What is causing lack of fuel pressure when engine is up to normal temp? If it was a defective pump I guess the problem should be there all the time?
Any ideas to solve the issue is very much appreciated
Regards Form Denmark
Karsten Horn
Old Apr 15, 2007 | 11:54 AM
rihwoods's Avatar
rihwoods
Electric or mechanical fuel pump ??? If mechanical,possible when cold diaphram tighter,ie not leaking thru much..then expands leaking more when hot....just a guess,though...
Rich
Old Apr 15, 2007 | 11:56 AM
vetteaddic's Avatar
vetteaddic
I had the same problem,couldn't figure it out for months,
It was my fuel filter .could be your problem.
Old Apr 15, 2007 | 12:01 PM
karstenhorn
I do have a mechanical pump and I’m not aware of how old it is as I have only had this car for 3 months – Fuel filter does not look like new but why would it act like that only when hot?
And, by the way no sign of fuel in engine oil.
The problem you had with the filter, did it behave the same way? I.e. fine when engine is cold and stuffed when hot.
Karsten Horn
Old Apr 15, 2007 | 02:41 PM
rihwoods's Avatar
rihwoods
Karsten Horn
The mechanical pumps have a rubber diaphram..heat could have some effect if it has small pin hole....but easy to change filter(s) first and eliminate that as a possibility...if that don't work..I'd suspect the pump....
Rich
Old Apr 15, 2007 | 03:01 PM
Mike Ward's Avatar
Mike Ward
Sounds like you have a case of vapour lock.
Do you have the stock GM with 3 ports on it? Many people make the mistake of substituting a 2 port pump.
The third port is required for the return/bypass line, makes sure that the pump has cooler fuel at all times.
Old Apr 15, 2007 | 03:37 PM
7T1vette's Avatar
7T1vette
I think you have a flexible fuel line that is collapsing and restricting flow when it gets warm (rubber softens as it heats up...probably from exhaust system). I assume you have an electric fuel pump and have not placed it near the fuel tank. Check the line between the tank and the pump.
Old Apr 15, 2007 | 05:52 PM
big_G's Avatar
big_G
Do you have the stock GM with [B]3[B] ports on it? Many people make the mistake of substituting a 2 port pump.
Replace the pump and make sure none of the fuel lines are near (very close) to the exhaust system. Replace the fuel filter also.
Old Apr 15, 2007 | 07:56 PM
tellcom2001's Avatar
tellcom2001
i have the same issue with my vette runs great cold..get it hot runs like crap..still working on the problem
Old Apr 15, 2007 | 08:52 PM
RodTeq's Avatar
RodTeq
ToolMan
I have the same problem when hot but it is infrequent. 1970 with 350/350. I replaced the fuel pump and got the return line functioning again (it had been plugged off). That helped but did not eliminate the problem. I am considering an electric fuel pump. Rob
Old Apr 16, 2007 | 12:29 AM
karstenhorn
I do have a stock 3 port GM pump with return line to the tank so I don’t think vapour lock is the problem. I have tested the fuel temp with my infrared tester and the system is not near boiling temps anywhere. I will change the filter/rubber hoses today and check again before I get a new pump to go on.
Thanks for all the good replies.
Regards
Karsten Horn
Old Apr 16, 2007 | 11:47 AM
karstenhorn
Changed the fuel filter today and absolutely no difference, did some more measurements with the infrared and the hottest spot is the bottom of the carb and that was around 165 F (top of carb around 125 F) and the fuel line/fuel pump around 120 F. I can hear fuel returning back to the fuel tank via the return line (Splashing) so do I have vapour lock or is it the pump?
A quick question, will any mechanical fuel pump for a 350 SB fit on my 400?
I can only get a pump listed for a 350, not a 400
Thanks in advance
Regards
Karsten Horn
Old Apr 16, 2007 | 03:08 PM
tellcom2001
i have a 2 line fuel pump is there supposed to be 3 lines?????????????
Old Apr 16, 2007 | 03:18 PM
Mike Ward's Avatar
Mike Ward
Corvettes never came with a 400, so you'll only find 350 cu in. Choose the correct pump for the original engine.
Old Apr 17, 2007 | 12:20 AM
karstenhorn
I have no idea what my 400 came from originally and I simply wanted to know if the SB fuel pump was interchangeable between the 350 and 400. Well, I found out that they indeed are by other means.
Regards
Karsten Horn
Old Apr 19, 2007 | 11:51 PM
ttaylor800's Avatar
ttaylor800
4th Gear
I'm in the process of changing up carbs and considering an new fuel pump. Edelbrocks and others have 2 lines vs. 3 (no vapro return). Is there a way to use a high permformance mechanical pump on the C3's with no return?
Old Apr 20, 2007 | 01:06 AM
TimAT's Avatar
TimAT
Regards
Karsten Horn
Pumps are the same with the exception of the number of ports.. They ARE interchangeable..
To Missing fuel pressure when engine gets hot.
Old Apr 20, 2007 | 07:55 AM
Bangkok Dean's Avatar
Bangkok Dean
Originally Posted by ttaylor800
I'm in the process of changing up carbs and considering an new fuel pump. Edelbrocks and others have 2 lines vs. 3 (no vapro return). Is there a way to use a high performance mechanical pump on the C3's with no return?
I just changed my Holley performance mechanical pump for an in tank electric with a return from the carb bowl to the tank. I have had big vapor lock problems ever sense removing the original return line stock pump. The RPMs would drop to nothing when it is hot in city driving.
Old Apr 20, 2007 | 08:12 AM
ttaylor800's Avatar
ttaylor800
4th Gear
Did your Holley Performance pump have 3 outlets with the vapor return line?
Old Apr 20, 2007 | 11:30 AM
Bangkok Dean
No it did not and that was the problem.
