Rollcage update (pics)
Old Apr 25, 2007 | 06:56 PM
  #41
73C34me's Avatar
73C34me
Looked at the chevy power manual diagram on cage install. Question, doesn't the main hoop have to be vertical to meet todays NHRA codes?
Old Apr 25, 2007 | 09:56 PM
  #42
Yellow73SB's Avatar
Yellow73SB
St. Jude Donor '07
Most of us don't even run NHRA or drag race for that matter. I don't it being a problem anyways.
Old Apr 26, 2007 | 12:06 AM
  #43
CorvetteDave01's Avatar
CorvetteDave01
NHRA manual says the cage can be laid back or forward, they just get picky about the 30 degree back, downtube angle (30 degrees from vertical) in respect to the main hoop. This is from what I have read in their manual anyway. Don't have any real experience with tech at the tracks yet...
Old Apr 26, 2007 | 12:14 AM
  #44
CorvetteDave01
I did decide to go bolt in. I just finished drilling 3/8" holes in 8 3/16" steel plates (4 to weld to the frame with nuts welded to the backside and 4 to weld to the bottom of the four tubes of the main hoop and back downtubes). Bought 16 grade 8 3/8" bolts that I will use to bolt it down, so it should be pretty rigid.
I also have already welded in the standoff by the drivers foot for the swing out bar, so it will be solid. Kind of wished I had bolted it in too, but too late now...
I may get it in this weekend and will post some pics if I do, have to shorten the hoop and downtubes by 6/16" inches to get it to fit now, then I will bolt it up, tack it in, and then weld the plates up solid.
Old Apr 26, 2007 | 12:31 AM
  #45
TheSkunkWorks's Avatar
TheSkunkWorks
From: Graceland in a Not Correctly Restored Stingray
Thanks for sharing your progress. Definitely keep us posted.
Old Apr 26, 2007 | 07:39 AM
  #46
GrandSportC3's Avatar
GrandSportC3
Cruise-In IV-V-VI-VII-VIII Veteran
St. Jude Donor '03, '06, '17
Mine is layed back and my and the rear bars are exactly at 30 degrees.. Never had any issues with tech inspections with it..
Old Apr 26, 2007 | 01:42 PM
  #47
73C34me's Avatar
73C34me
Oliver, does yours mount to the frame behind the seat, or the frame kick?
Old Apr 26, 2007 | 03:19 PM
  #48
GrandSportC3
Here's the way mine is setup. It will clear the convertible top..
Old Apr 26, 2007 | 03:23 PM
  #49
69autoXr's Avatar
69autoXr
What about your head? It looks pretty low for a convertible.
Old Apr 26, 2007 | 03:28 PM
  #50
GrandSportC3
My seat is about 3+ inches lower than the stock seat.. I'm 5'11" and my head is below the top of the head rest part of the seat with the helmet on.. The seat position was chosen for multiple reasons..
1) I was sick of always hitting my head (with the helmet on at the hard top when getting out of the car
2) It made it easier to make the roll bar clear the soft top
Look at this pic how low my seat is.. The top of the seatinf surface is less than 2 inches from the floor..
Old Apr 26, 2007 | 03:30 PM
  #51
69autoXr's Avatar
69autoXr
WOW! Can you see over the fenders?
Good thing the christmas tree is mounted up high!
Old Apr 26, 2007 | 03:38 PM
  #52
TheSkunkWorks
Ouch, GransSportC3. That unpadded bar hurts just looking at it. Tech hasn't said anything?
  #53
GrandSportC3
Vision is good.. However if I'd be less than 5'8", vision would very limited.. My seat has no tracks. It is mounted fixed in place. If somebody else would drive the car, the seat would have to be mounted differently... I've made about 160 passes in that seat position and drove about 200 miles on the street with no issues...
Old Apr 26, 2007 | 03:39 PM
  #54
GrandSportC3
The bar is padded now .. The pics were taken when I had it installed 2 years ago..before I installed tha padding..
Old Apr 26, 2007 | 04:51 PM
  #55
68 NJConv 454's Avatar
68 NJConv 454
Oliver, does that "wing" really help in the 1/4? did you notice a difference in how the rear handled?
Old Apr 26, 2007 | 06:29 PM
  #56
Bee Jay's Avatar
Bee Jay
Here is my autopower, welded in, on the frame rise. They had to make a short version for it to fit where it is. It definitely stiffened the frame.
Old Apr 26, 2007 | 08:34 PM
  #57
GrandSportC3
I don't think that the wing makes any difference. It was on the car when I bought it.. If it wouldn't be that expensive to do it, I would have it removed...
To Rollcage update (pics)
Old Apr 26, 2007 | 10:35 PM
  #58
CorvetteDave01
That is a sturdy looking cage Olivier. I know what you mean about the seat height, I have been thinking about trying to cut mine down, maybe take the rails out or something.
BJ, nice cage as well. Very similar to mine.
Old Apr 26, 2007 | 11:02 PM
  #59
GrandSportC3
The guy that did mine has been building race cars since the late 60's.. He knows his stuff and he is very inexpensive. The lower seat height has many benefits....
Old Apr 28, 2007 | 10:47 PM
  #60
CorvetteDave01
OK, here it is mocked up. I have the plates with welded nuts (on the bottom side) under the hoop/brackets, hard to see them, but that is what the loose bolts are threaded into. Just need to take the bottom plates to the frame, pull out the hoop, weld up the bottom plates, then finish the top of the swing out bar and I'm done other than repaiting. No interior panel cutting modding required!
Guess I will have to fab up some access plates as well. I'm also going to make an L bracket to go over the OEM seat belt holes, so I can get some strength back into them, but still have the stock replacement seatbelts functional.
I was particularly happy about how tight the hoop is to the door and the ceiling.
