Replacing Radiator. Advice?
About how long should it take?
Will I need any special tools other than patience?
Remove the hood.
Remove the fan.
Remove the radiator support with the radiator. (Look for the bolts in the wheel wells).
When you have the radiator and the support loose, tilt them forward and remove the shroud - in one piece.
After removing the hood, one person can do this in 2 hours.
Your advice is very appreciated!
Now a few more questions, forgive me if they seem unintelligent.
Since I am going to be replacing the support and the radiator all in the same day (prays this is possible). Would it be easier to unbolt the support and lift it out as one unit or take it apart piece by piece?
I don't know a whole lot about vette's this being my first to work on and own. The radiator support isn't a crucial part of the frame is it?
I will be able to just unbolt the support and slip, pry, pull, tug, and beat the support out and then just put the new one in, right? Or am I being naive here? The body pieces don't have to come off do they? The hood I can deal with, but would rather not, based on past experiences with old trucks.
I did find out today that the support is a 1976 support, the vette is a 74. Is this as bad as sign as I think it is?
This will be the first major restore event that I will being doing to the car. I spent the last 2.5 months of just keeping it running and the wheels turning on the ol' car.
Most likely I will be the only one working on it. How big of a bottle of asprin am I going to need?
edit in:Thank you BK.
Remove the hood.
Remove the fan.
Leave the hood alone. It is a hassle to realign and soon we will see posts from you about "How do I get my hood open, it's stuck" where it catches wrong.
Leave the support alone. It aligns the front fenders. You ready to have front surround cracks? It also has the AC lines and vacuum lines for the headlights.
Drain the coolant.
Remove any air intake ducting you have, like on '76 to '81.
Remove the hoses.
Remove the transmission lines, if an automatic.
Remove the fan shroud and slide it back.
Take a big thick piece of cardboard and slide between the fan and the radiator. It helps to turn the fan so that two blades help support it at top.
Unbolt the radiator clamps.
Pull the radiator up and out, with some twisting to get the lower connection to clear the a-frame.
30 minute job, I don't know what these other guys are doing.
Leave the cardboard in. You can slide the radiator along the cardboard to get it back in, too.
Drain the coolant.
Remove the hoses.
Thanks for the tip about the cardboard.
It's an automatic, has a/c and vacuum headlights. It is a 74 with a 76 radiator support and I assume a 76 radiator that is on its last leg.
Since the support controls the alignment of the fenders would it be better to have a shop do it?
Edit: I could get mine out in under 30 minutes but it would involve unchaining it and hitting a big bump! Getting the radiator itself out isn't what I am worried about. It is the support and everything that I now realize that is connected to it.
Before you mmake the big leap, you want to ensure you have replacement seals for the radiator and the fan shroud. Leaving the seals out will lead to overheating.
I am pretty sure I order all the replacement seals. 70% are still in place and I will use the old ones if I find I forgot to order one.
If I leave the hood on, would that help keep everything in place as far as the front end fiberglass and all that stuff? Sort keep things squared up?
Thank you for your answers!
7T1vette, so what you're saying is keep the shroud intact and get all the seals back in place, right?
I would agree with the others; the hood should be removed to give you access to the radiator and shroud. Be sure to put "positioning" marks around the hood hinge plates, so that you can re-align the hood easily.
That is going to take a lot longer than 30 minutes.
The two slowest parts I've found on the radiator removal is waiting for the coolant to drain and getting the darn transmission lines out. I know why so many cut them.
Replaced the thermostat today in the Napa parking lot. The upper radiator hose decided to pop off the thermostat housing while I was inside Napa!
And of course it spewed around 3 gallons out onto the parking lot! No studs. The shroud bolts on. It appears to be the wrong shroud, cut outs for upper and lower radiator hoses when they aren't in the way. Doesn't fit right up to the support in some places. Also I picked up the upper radiator hose for a 74 and it doesn't come close to fitting using the current set up of support and radiator....wait and see if it fits with the new support and radiator?
So now the general advice is;
mark the hood placements,
remove the hood,
take the fan off,
take the shroud off without or as little damage as possible,
disconnect transmission lines and A/C lines,
pull out radiator, then the support. support is too far gone to pull as one unit. the radiator would fall out as i pulled the support out!
put new support in,
connect lines back together,
put new radiator in new support with seals,
put top brackets back in place with seals,
put radiator hoses back in place and put hood seals on,
refill with coolant.
Transmission fluid? I expect that is going to leak some too, while I disconnect the lines. A/C, I don't think it has any freon left in it. Doesn't cool at all. So as far as those lines that don't like to be disconnected. Any tricks anybody is willing to share to make this less of a hassle?
Thank you all again for your advice.
