Leak Down Test Acceptable Values
Old Jun 5, 2007 | 08:58 AM
KJL's Avatar
KJL
Default Leak Down Test Acceptable Values
I checked my engine last night and 7 cylinders came in at approx 6% and the one was at 9%. The cylinders were also relatively dry. Car has been sitting for about 6 months. I have been spraying fogging oil into them however. I did not index the pistons.
Old Jun 5, 2007 | 09:27 AM
zwede's Avatar
zwede
If you sprayed oil into the cylinders the test won't tell you much except that your valves are sealing. You should run the engine up to temp and then do the test again with the engine hot (or atleast warm if you don't like 2nd degree burns). If the leakdown still comes in under 10% you're good.
Old Jun 5, 2007 | 09:43 AM
Duke94's Avatar
Duke94
My gage shows anything less than 30% to be "good".
Old Jun 5, 2007 | 09:53 AM
markdtn's Avatar
markdtn
I have always heard 10%
Old Jun 5, 2007 | 10:58 AM
lars's Avatar
lars
I think I'd use some white-out on that gauge... A 30% leakdown rate would indicate serious engine problems. In fact, if' you're seeing leak rates above 15%, there are issues with the engine that should be addressed. We just tore down a 406 that was showing 17% on a couple of cylinders, and we found problems with cyinder bore out-of-round and rings that had failed to seat on those cylinders. The engine passed compression testing, but was a "fail" on the 17% leakdown on 2 cylinders. The other cylinders were under 10%. A well-built engine will easily be in the 5-7% range.
Old Jun 5, 2007 | 11:25 AM
gkull's Avatar
gkull
If your have a motor that uses oil and has visible smoke they will LD test in the 10-12% By 15% you are talking a quart every tank or so and the motor will have a noticable power loss.
The modern 1/16th racing rings on forged pistons doing RPM are usually gone by 20,000 miles. 3-4% leak down can be done on well built motors.
KJL - Are you saying that you did not index the rings? End Gap and index are important.
Old Jun 5, 2007 | 01:16 PM
KJL's Avatar
KJL
No, I know folks who check leak down with all pistons at the same stroke position in the cylinder for consistency because cylinders wear differently due to varying lateral loads imparted on the cylinder walls through the stroke.
I am interested to compare the "cold" values to a warm engine.
Old Jun 5, 2007 | 02:09 PM
lars's Avatar
lars
You have to test the cylinders with all pistons at TDC - if not, you'll have open valves. Also, if each piston is not at TDC, the pressure you put in the cylinder will rotate the crank. You cannot perform a leakdown test unless you put each piston in exactly the same position at TDC.
Old Jun 5, 2007 | 02:20 PM
gkull's Avatar
gkull
When you ran the check did you listen near the block to see if the leak was all ring blow by? Lars brought up a good point on TDC. Any valve leakage in modern SS valves is not from valve or seat erosion. It is a problem of miss adjustment or even bent valves. Let me take this back. You really need to do a leak down test right after assembly and again after break in. Keep these records along with all your clearance information as a future refference
zwede's Avatar
zwede
Actually, it's a very good idea to do a LD test away from TDC as well. This will show damage that is not visible at TDC. For instance, if you have a wrist pin that has walked out and gouged the wall... at TDC the rings will still seal, but as soon as the piston goes down the bore it leaks like crazy. The valves will be closed 45 crank dgr BTDC to 45 dgr ATDC (minimum. most engines have closed valves much longer than this), so that 90 dgr is testable. On a stick shift, just turn the crank to the desired place and put it in high gear to lock the engine. Dunno what to do on an automatic????
When my motor was shot it tested 16% at TDC. Bad, but not horrible... but when I tested 15 dgr BTDC it was 92%!!!
Old Jun 5, 2007 | 02:24 PM
zwede's Avatar
zwede
Originally Posted by gkull
If your have a motor that uses oil and has visible smoke they will LD test in the 10-12% By 15% you are talking a quart efvery tank or so and the motor will have a power loss.
Not always. You can have good oil control rings and bad compression rings. My engine only used 1Q/1500 miles, no smoke. Yet leakdown was 16% at TDC, 92% 15 dgr BTDC. So although it didn't burn oil, it pressurized the crank case and pushed oil through the PCV and fouled the plugs. But still only used 1Q/1500 miles.
Old Jun 5, 2007 | 03:16 PM
KJL's Avatar
KJL
I know my valves were closed because I did it with my valve covers off. I turned the crank until each cylinder was in the compression cycle and the valves were closed then I put it in gear.
My blow-by was deff through the rings. The heads are new AFR's. I am not to concerned about them.
Old Jun 5, 2007 | 03:31 PM
GTR1999's Avatar
GTR1999
This is a good thread as I have to do the same thing with my 350. It has 1200 miles on it and used about 2 qts already. I haven't had time to do anything to it other then pull the plugs. #1,5,7 2,6, and 8 were oil fouled. The insulator was only fouled 180* on most. No leaks but I can smell oil burning under load. Oil film on bumpers. I file fit the rings and the cylnders were supposed to be honed for the supplied rings. I haven't pulled the PVC line to see if there is any oil in it. I was going to do a leak test then compression test. Any other thoughts?
Old Jun 5, 2007 | 05:12 PM
Duke94's Avatar
Duke94
All my cylinders check 20-30% leak down. The short block is a Goodwrench with Edelbrock Aluminum heads and has less than 1500 miles on it. Is my gage that far off or do I have a problem? It doesn't burn any oil and compression is 170-180 PSI on all cylinders.
Old Jun 5, 2007 | 05:31 PM
lars's Avatar
lars
I don't know how that's possible unless you have bent valves or a defective gauge. At that kind of massive leakage, you will hear the air whistling out of the leak source: You'll hear air whistling out the valve covers if the rings are bad, out the carb if the intake valves are bent, and out the exhaust pipe if the exhaust valves are bad. But there is no way you can have a defect-free engine with a 30% leakdown rate unless the guage is bad or the test is being done with the valves open.
Lars
Old Jun 5, 2007 | 08:29 PM
Duke94's Avatar
Duke94
Lars
I can hear air leaking (constant hissing soumd) from every cylinder. Would I hear almost nothing at <10% leak down? Can't really tell where it's leaking, for sure not exhaust or carb. I have the intake manifold off now, so maybe I will hear it better.
To Leak Down Test Acceptable Values
