Hood Insulation question...
Old Aug 7, 2007 | 10:01 PM
vetteguy75's Avatar
vetteguy75
LA Events Coordinator
Default Hood Insulation question...
Two questions: What is the purpose of the hood insulation...for sound suppression or "paint-blistering-on-the-hood" prevention? AND what is the BEST adhesive to anchor those pesky plastic tips???? Mine just fell off AFTER I just installed it about 2 months ago. I used a quick set epoxy glue....is it possible that the "quick-set" causes the epoxy to become brittle when exposed to the engine bay heat?
Old Aug 7, 2007 | 10:07 PM
7T1vette's Avatar
7T1vette
To the best of my knowledge, the hood insulation for C3's came out when the engine thermostats went to 195 degrees (1973, I think). Prior to that, no insulation for 180 degree engines. It can be helpful if you have A/C... if a compressor clutch fries, it will blister the hood without insulation [ask me how I know]. Insulation can't hurt anything under the hood of any C3, unless it impacts the intake air path.
Old Aug 7, 2007 | 10:21 PM
vetteguy75's Avatar
vetteguy75
I agree...so what is the BEST adhesive to use?
Old Aug 7, 2007 | 10:26 PM
Artsvette73's Avatar
Artsvette73
Fusor from Lord Corp. has adhesive metal to glass
Old Aug 8, 2007 | 09:48 AM
Lon Wayne's Avatar
Lon Wayne
Default Vader vette
J B Weld then tape them on with blue painter tape been there did that got my insl from Paragon Looks great used my old discs and glued A couple deals on then painted around the out side area looks like factory.Shined disc up with bench grinder.
Old Aug 8, 2007 | 12:48 PM
markdtn's Avatar
markdtn
Originally Posted by 7T1vette
To the best of my knowledge, the hood insulation for C3's came out when the engine thermostats went to 195 degrees (1973, I think). Prior to that, no insulation for 180 degree engines....
Actually I believe some '69s have insulation. AIM shows a full piece I believe, but only about 1/3 of a sheet was used on the cars that got it. Not used '70-'72. Then it started again in '73. That is from memory, I could have some details confused.
Old Aug 8, 2007 | 01:01 PM
S489's Avatar
S489
probably not the official reason, but i noticed a long time ago when running the car long enough followed by a short shower that the water on the hood would quickly vaporize. imagine steam rising from the hood. neat . . . maybe a little distracting . . .
Old Aug 8, 2007 | 01:09 PM
VettePower's Avatar
VettePower
I took it off my 77 years ago, and never had any paint or steam problems...
Old Aug 8, 2007 | 03:50 PM
Belgian1979vette's Avatar
Belgian1979vette
The hood I used came from a car with AC and I already noticed that they removed the air and that there was some fire within the system. The hood had some burn marks on it. The insulation was already removed, so this could be right.
To Hood Insulation question...
