Update-Pressure-bled the brakes one more time, then got the car back on all fours and took it for a cruise. Pedal is about the same as it was before I started all this(about 1 1/2 off the floor), car stops on a dime, plus now I know there aren't any leaks!
I'll check for a blown booster(it's only two years old), otherwise I think the brakes will be alright.
Thanks to everyone that responded
good! every spring ~20 guys do the same thing. Eveybody wants to be sure the brakes are perfect before driving the car at all.
Each and every day i drive i press the pedal as i back out. Can't tell much if anything unless it is moving.
