Polishing crank
Old Sep 23, 2007 | 11:51 PM
shmoky's Avatar
shmoky
Default Polishing crank
Do I need to take my crank to a "professional" grind shop to get it polished? I'm not getting it ground.... just polished. The bearings all have some wear (grooves) from a cam lobe being wiped. But the crank seems to be okay and I have been told that it just needs polishing. How important is it to take it to a VERY reputable shop? Or is the local shop with the right equipment enuf? I will be talking to the small local shop tomorrow and I'm sure he will say he can do it (more business for him). If not him then I have to ship it several hundred miles away. Any and all opinions needed.... Thanx.
shmoky
Old Sep 24, 2007 | 12:37 AM
7T1vette's Avatar
7T1vette
If the bearing journals have "grooves" large enough for your fingernail to feel, you really need to get the journals re-ground. If you just polish and put new bearings on "grooved/distressed" journals, you will be asking for more problems. I can't imagine the cost savings from not doing a re-grind being worth the risk.
Old Sep 24, 2007 | 08:28 AM
bashcraft's Avatar
bashcraft
Have you had the crank checked to make sure it's within limits?
It only takes a shop about 10 minutes to polish a crank. Any shop with the equipment can do this. The last one I had done cost $15.
To Polishing crank
