Blinker Gremlins
Old Oct 8, 2007 | 09:59 PM
mrlucio79's Avatar
mrlucio79
8th Gear
Default Blinker Gremlins
Everytime I turn on my blinker it gives my speedometer hand a heartbeat, dims the guage lights, and radio with every second of the blinker. Could a short be causing this or is it a short? Sorry for asking all these questions, I am patiently waiting for my Chilton Corvette manual and my large print of the wiring diagram to my 82 corvette. And yes I am a newbie to auto mechanics.
Old Oct 9, 2007 | 10:28 AM
Durango_Boy's Avatar
Durango_Boy
That's fairly normal with a lot of cars. Replacing the signal and hazard flashers with more modern electric flashers may guard a little against the dimming.
Also, consider having your alternator tested for output. If it's losing a step and your system voltage as the signals is around or under 12V then dimming may be caused.
Old Oct 9, 2007 | 07:21 PM
7T1vette's Avatar
7T1vette
You have a grounding or electrical supply problem with the flasher system. Something is drawing it's electricity through a different sub-system, hence the interconnection between systems. You need a good auto electrical guy.
To Blinker Gremlins
