Oil gauge
Old Nov 29, 2007 | 08:52 PM
gbags's Avatar
gbags
Default Oil gauge
Today while cruising I noticed my oil gauge was on 0 at a traffic light!
As I started from the light it went to 20. The car did not clatter from valves or run any different. I then drove the 10 miles home cruising at 45 mph. No oil on the ground or rough engine just normal smooth.
This is a stock 350 78'. Any thoughts on what to check?
Thanks I only have 500 miles on an oil change after the car has sat up since 2002. I bought it and changed the oil in May.
Old Nov 29, 2007 | 09:16 PM
sdonnelly's Avatar
sdonnelly
It would be easy enough to temporarily change the oil pressure gauge and sender to see if that's the problem, but you could do damage to the engine finding out, if the current one is good. After sitting five years you could have had sludge and junk just now coming loose, clogging stuff up, like the filter and oil pickup on the pump and other passages. Would that cause a higher reading? I'm no great engine guru. If it were mine, I'd change oil and filter again and then take it in somewhere to get the engine flushed and new oil and filter, again. that wouldn't hurt anyways. Then if you still see trouble try the gauge for a few miles. Still bad, drop the pan and replace the pump.
That would be my steps. But again, I've blown a motor or two.
Old Nov 29, 2007 | 10:03 PM
wnmech's Avatar
wnmech
If it were me first checking the obvious like sdonnelly said change the oil and filter see what comes out of the pan then I would buy a direct reading gauge to verify actual oil pressure and go from there. More than likely it will be that transmitter.
Old Nov 30, 2007 | 07:27 AM
markdtn's Avatar
markdtn
Get a cheap mechanical gauge and try that first, likely the sender is bad.
Old Nov 30, 2007 | 09:39 AM
gbags's Avatar
gbags
Ran car today and oil gauge worked for 5 minutes when at idle it goes to 0.? I will replace sender and see what happens.
Old Dec 1, 2007 | 03:01 AM
johnnybrewmeister's Avatar
johnnybrewmeister
FWIW, and just a data point, but my guage usually drops to about 0 at idle, and then climbs up to 35-40 while cruising. Been that way since I bought it (about 8 years ago) and I haven't worried too much about it.
Somebody let me know if this is bad (!) and I should fix something.
Old Dec 1, 2007 | 10:47 AM
7T1vette's Avatar
7T1vette
The calibration accuracy of the stock dash oil gauge is pretty poor. If the car is left to idle for a minute or so without any lifter clacking, it likely has adequate oil pressure (5-7 psi at idle). Replacement senders may not be directly compatible with your old sender...investigate thoroughly before you inve$t.
To Oil gauge
