Hi guys, I'm not trying to highjack this thread. I wanted to know if this system will fit on an 80 4-speed car, or will I need a new crossmember? If I do need a crossmember, what years would make good donors and where can I find one. http://store.summitracing.com/partde...40+4294920008+
If you have an '80 manual car then I think your cross member is welded in, and would have to be cut out to be replaced with a bolt in style.
I bought the stainless Pypes system from Summit. It has a 2.5" dual exhaust with the x pipe in stainless steel. Cant tell you how it works yet as I am going to install this weekend hopefully. I had another thread running asking if anyone else has done this and so far no takers. But it is a really beautiful system lying under the car, just hope it all fits up as good as it looks..... You can run it with either headers or the OEM exhaust manifolds.
L82Shark - did the install happen? Curious to learn more and maybe see some pics. Thanks.
No, ran into a problem with a bent crossmember. Going to replace it before I go any further but I did lay the system out and take some pics. I dry fitted everything on the ground and it went together smooth. Looks like it comes with everything you need.
If I can find a new crossmember will try again this weekend!
Reason: fixed picture
Thanks for the pics - that system really looks sweet.
A couple other questions....
1. Are you connecting to stock manifolds?
2. You mentioned your muffler choice, how does that compare (sound wise) to the magnaflow? Also, is there a price difference?
3. How long did it take to arrive after ordering?
Ok, slightly more than a "couple" questions
I was going to use the stock manifolds but I changed my mind and have new headers to install with it.
I went with the Racepro, they have some soundbites on their website with some testimonials and it seemed these were more to what I wanted than the streetpro.
It took about 3 or 4 weeks for it to get to me. Ship date kept changing, I dont know if that was because I was using Summit as the middle man or what. But the $$ between the website and Summit made it worth the wait. It actually arrived a couple of weeks before the last estimated ship date Summit sent me. I was going to use the time to make sure everything was ready when it got here but I got hung up on the body mounts and rear end rebuild. Hope this helps.
Thanks for the update. Looks like a good system. What year is your car and what transmission do you have? I tried hedman header extension on my 75 with a th400 and the 2.5 mandrel pipe hit the tranny pan. I also have a b&m deep aluminum pan so that my be it.
Forgot to mention one thing, if you currently arent running duals make sure you order a dual exhaust hanger kit, no matter what system you go with. It helps tie the exhaust up through the crossmember openings so it doesnt bang around.
What about one of our supporting vendors: http://www.corvettecentralexhaust.com/
I got a true dual for my 78 and it was easy to install. Had to buy a bracket to change from single pipe support at the transmission to a dual pipe support. Wish my car was out of storage, I would have sent a picture.
Their kits are a good value and easy to install in most cases without welding. They also have options for different mufflers depending on your need for loudness.
