handling
That's kinda true. You know, my 1980 on the scale was 3135 lbs. In regards to the "later C3's" Yes, you are correct but later-later C3's, the 1980 went on a diet with the thinner glass, thinner frame, more aluminum in place of steel etc.
After all of my weight reduction (especially that big @ssed 9 leaf rear leaf spring) has really made my C3 comparatively nimble for its size. Plus, it looks rad as h#ll
Oh...My set-up is very easy for street & track/autocross:
Functional & attractive
It's handsomely lowered
1. VB&P 360# rear mono
2. 550# front coils
3. New Bilstein Sports all the way around
4. 1&1/8 front sway and the really dinky rear sway
5. New poly bushings
6. Rebuilt the steering box
7. new idler arm
8. new PS pump
9. New PS control Valve
10 New SS brakes
All of the upgrades were relatively easy/bolt-on items.
The car rides sooooo much better & handles safer too.
I could easily spend more but that wouldn't really enhance the cars drivability to me for what I use it for.
The only thing I would've done differently would probably have just installed the steeroids rack system. Redoing all of the OEM stuff was just about as expensive when all added up.
Just a suggestion to those thinking about a front end /steering rebuild.
We're on pretty much the same page here as I love my heavy springs, and IMHO no one should knock em' until they actually try them. I've done a few cross-country trips on the Daytonas and they just aren't as bad as all the "propaganda" out there against them...
Sometimes the jarring rides you hear about are likely due to overly stiff shock valving and/or overly stiff bars on uneven surfaces (where only one side of the car experiences an upset). Or, perhaps my backside is just better acclimated from all the pounding around places like Sebring.
read through this. Should only take you a few hours.
http://forums.corvetteforum.com/show...hlight=junkies
I'm reading about massive front spring rates and small sway bars. If you drive on the street you need some ride comfort and you don't need to pull a g on the exit ramp.
So far no one has even defined what they mean by handling. We need to get back to the basics and define exactly what it is we're trying to do here.
Handling really consists of 5 things.
*Response - The time between input to output
*Precision - The consistency of output from a fixed input
*Gain - The amount of output to a given input
*Progression - The consistency of the gain
*Balance - Bias toward oversteer and understeer
Improving the handling of you Corvette would mean improving one or more of these five items.
Richard Newton
Wheel and Tire Performance Handbook
How to Restore and Modify Your Corvette, 1968-1982
Auctionman - If you want to take the easy way out, just get a full front and rear suspension kit from one of the vendors here. I got the VB&P Performance Plus System along with new wheels and tires. The difference in handling is night and day.
Have a built Binford small block more power!!!
I have ran the car in many auto cross events and have always won my class.
Chris, are you throwing down the gauntlet???
